Howdy!
I've recently installed and tested my new NexDome with my EQ8-R. I use EQASCOM for the mount, the newest NexDome ASCOM driver, and POTH as the dome hub. Everything seems to be working well, the dome aligns properly with the scope and everything. Last night was my first imaging run. Everything went well until the meridian flip, where the scope flipped and the dome moved, but NINA started the plate solving image before the dome finished slewing. Since it was imaging the inside of the dome, the plate solve failed and it just hung after that.
After a little testing this morning, when I issue a slew to POTH, it shows "slewing" as the scope moves, and once the scope reaches the target, it doesn't show "slewing" anymore, even though the dome is still moving. After a good bit of searching, everything I see shows that POTH is supposed to report as still slewing until the dome is finished moving, too. But, this doesn't seem to be the case for me.
Is this an issue in POTH? A setting that I missed somewhere? An issue with the NexDome driver?
Thanks for any advice!
