10” LX200 error code
1 reply to this topic
#1 Able 12 ISONS
Able 12 ISONS
Posted 17 October 2020 - 07:28 PM
I have a 10 inch LX 200 ACF GPS. Approximately three years ago I purchased and installed a new motherboard from mead for the telescope. It worked perfectly, I have other telescope so I do not use the 10 inch that often Approximately 25 or 30 times after installing the new motherboard. Two weeks ago I set up the telescope in the backyard and it would not align. I went through the Set up procedure A couple of times Every time I reach the daylight savings time setting telescope will freeze. I tried bypassing the daylight saving time setting and it still froze. I tried using a brand new hand box not the problem. The error message on my hand box reads ( PROC. 2. TARP ) any ideas? thank you in Advance.
Edited by Able 12 ISONS, 17 October 2020 - 07:38 PM.
#2 OzAndrewJ
OzAndrewJ
Posted 17 October 2020 - 07:36 PM
Gday Able 12 ISONS
"Proc Trap2" occurs when the CPU reads a command that it cannot interpret.
If it is happening at the same spot every time, it sounds like you may have corrupted firmware.
This might just be slow/local "bit rot" or it might be the start of something more terminal.
In that case, you will probably need to try reloading the firmware first.
If you do, i suggest using the freeware StarPatch loader
http://www.stargps.ca/downloads.htm
as it has better logging and error trapping.
If that shows errors trying to erase or write, then its more likely the board is dying.
  • Able 12 ISONS likes this
