APM-LZOS 130/1200 with 98.9 % Strehl for sale
No replies to this topic
#1 APM M.Ludes
APM M.Ludes
    Vendor (APM Telescopes, Lunt Solar Systems, Lunt Engineering)
  • Restricted Vendors
  • Loc: Germany
Posted 18 October 2020 - 02:58 AM
APM-LZOS 130/1200 with 98.9 % Strehl for sale for US $ 5,990.00 include shipping from germany
APM / LZOS apo refractor 130mm f / 1200 mm 3.7 "ZTA
130mm at a great price
The "little brother", if you want to put it that way, is the version with an aluminum tube and 3.7 "ZTA extract. With regard to the optics, exactly the same should be noted as with the CNC-LW II model, only the selection of the focuser is different, here the APM focuser is installed, which of course can also be rotated 360 °.
With a focal length of 1200mm you can already achieve high magnifications with a moderate focal length of the eyepiece, which e.g. the viewing position on the eyepiece is good for you! Since the radii of a longer system are not so extreme, this optic is ready for use more quickly because it cools down more quickly. The chromatic correction achieved is excellent and enables absolutely convincing contrast values! Binocular observations e.g. on the moon, Jupiter or Saturn (my favorite) become a pleasure! If the air is calm, this optics resolves so finely that you almost experience a "cinema feeling"! With a 130mm aperture you already have almost 70% more light collecting area than a 100mm device. The resolution is already improved by approx. 30%. The illumination is completely sufficient to be able to "operate" larger CCD sensors. Our specially manufactured reducers and correctors turn these optics into a high-performance photo machine!
An interferometric test protocol is included so that you know what you are getting.
In terms of equipment, everything important is already included: Slidable dew cap, end cover, viewfinder bracket, CNC pipe clamps and the necessary visual adapters / reducers. The device is of course transportable, as is the LW-II version. As an observatory, this refractor cuts a fine figure!
The price-performance ratio is excellent! For this optical quality, the competitor sometimes has to dig deeper into his pockets!
delivery include :
• Optical tube
• LZOS test report
• 3.7 "APM rotary extract (ZTA)
• APM Fast Lock reducing adapter 2 "/1.25"
• Set of APM CNC pipe clamps
• APM 3 "mounting rail
• Dust caps
• Handle
• Transport case
