Greasing a classic C8 mount
9 replies to this topic
#1 ANM
ANM
  • Loc: El Paso, Texas, USA, Earth, Sol system, Orion-Cygnus arm, Milkyway
Posted 18 October 2020 - 01:16 PM
I have another question regarding a C8 classic mount: do the clutch and brake surfaces get greased? It is metal on metal so I thought yes but it will mean that higher pressure is needed for the clutch and brake to work. But without grease it's metal on metal (or nylon on metal). In later C8s there are the three hex-head nylon bolts that press on the side of the aluminum worm wheel, this I think should be greased since the worm wheel rotates (even though it's slow) and the nylon bolts are stationary. But what about the RA lock lever's nylon pad?
One mount I have been working on had everything that rubbed on anything else greased, is that really necessary?
  • Photo-Dave likes this
#2 Photo-Dave
Photo-Dave
  • Loc: Reading, PA
Posted 18 October 2020 - 01:46 PM
I have 2 late 70’s C8’s. The one I’m using now doesn’t always track the object when I lock the slow motion adjustment wheel. So I’ll be following this thread, hoping to learn the finer points of use & maintenance of the dual motor clock drive. When I lock mine in it will sometimes drift in the other direction. Then I’ll turn the knob slightly and it will start tracking correctly. It’s very frustrating, especially when I’m trying to capture a planet on video.
#3 davidmcgo
davidmcgo
  • Loc: San Diego, CA
Posted 18 October 2020 - 02:43 PM
I would not grease the pressure plate or mating surface of the slow motion gear.  Loosen the clamp completely for large slews but some drag when fine tuning is OK.
Dave
  • ANM likes this
#4 ANM
ANM
Posted 18 October 2020 - 05:27 PM
Are you sure you don't need to adjust the RA locking lever? With it locked it should track,
P.S. the default state, and you shouldn't be able to rotate the mount in RA by hand.
Edited by ANM, 18 October 2020 - 06:31 PM.
#5 Photo-Dave
Photo-Dave
  • Loc: Reading, PA
Posted 26 October 2020 - 02:01 AM
Sorry for the long delay in getting back to you. Thank you for your reply. Could you please explain a bit more on how I can adjust the RA Locking Lever? When it is locked should I be able to rotate the Mount by turning the RA control knob? Thanks again. I look forward to your answer. Dave
#6 Photo-Dave
Photo-Dave
  • Loc: Reading, PA
Posted 26 October 2020 - 02:12 AM
How do I disassemble the mount to get to this area of the Clutch & Brake? I have 2 early orange tube C8’s that I need to service to track as best as they can for their age. Thanks again, Dave in PA.
#7 ANM
ANM
Posted 26 October 2020 - 08:57 AM
Do not use the RA knob to try and force the mount to rotate in RA, you can strip the teeth on the gear.
When you are tracking the lever should be turned to the left (locked). To turn to a different celestial object first release the lock, then rotate to the object and lock it again.
When the RA is locked: if you can put moderate pressure (not excessive, you're not trying to break it!) on the OTA and turn it either the RA lever is not locked or the lever needs to be adjusted. If the lever needs adjusting:
  1. unlock  the RA lock, loosen the Allen set screw that is normally hidden (don't take the set screws out, just 1 or 2 turns)
  2. turn the lever to lock it
  3. loosen the second set screw (the one you can get to when it is locked) so the lever is free
  4. rotate the lever slightly to the unlocked position
  5. tighten the set screw
  6. test it again and repeat as necessary
  7. tighten the other set screw
When you hang cameras and 2" accessories on the back of the C8 the balance can be thrown off making the RA lock less effective, it will also make it more difficult slewing to an object. If it's out of balance, you may need balance weights, either Celestron's (sometimes available in the classifieds on CN), or some third party system.
Edited by ANM, 26 October 2020 - 09:01 AM.
  • ShaulaB and Photo-Dave like this
#8 Photo-Dave
Photo-Dave
  • Loc: Reading, PA
Posted 15 November 2020 - 08:26 AM
Hi, sorry again for the big delay in getting back to you. I really appreciate the detailed instructions. I just want to confirm something. With the RA lever locked should the RA knob NEVER be used for tracking adjustments?
I thought it was for manual slow motion correction when tracking, Same for the Dec Adjustment Control. That’s how I’ve been using them. I Will Adjust the RA knob and test the results.
I do have a small bar hanging the full length of the underside of my C8 that I’ve been told is for weights. Unfortunately I don’t have the weights. I’m sure they are not an easy find. Any thoughts on alternatives to hang off there for balance when I do use my DSLR?
Thanks Again, Dave in cloudy PA
#9 davidmcgo
davidmcgo
Posted 15 November 2020 - 10:39 AM
Unfortunately the R A slow motion was not designed to work with the clutch engaged fully.  Also the clutch design changed a bit over the years.  The mid 1970s used a metal plate that would allow some movement with the clamp partially engaged but the later die cast forks went to a nylon plate with metal flakes molded in it that pretty much just went from off to solid grab with no in between.
Dave
  • ANM likes this
#10 ANM
ANM
Posted 15 November 2020 - 11:58 AM
Dave is right, the RA slo-mo knob is not to be used for fine-tuning while locked and tracking.  That being said you can, if you're careful, have the RA lock partially disengaged so you can do what you want but not so tight that you'll destroy the gears... probably. But then you have the possibilty that the mount will slip in RA when you don't want it to.
For photography you really need a drive-controller so you don't have to touch the scope at all.
The Dec slo-mo knob can be used anytime though the vibration won't be acceptable during photography.
RE the weights: try https://www.admaccessories.com they might have something.
