MB II and Naglers ?
5 replies to this topic
#1 MrRoberts
MrRoberts
  • Loc: Barrington, Illinois (60010)
Posted 20 October 2020 - 08:46 AM
I have only had one BV (Celestron) an found it very disappointing. So I am thinking of trying the MB II to go with my C-8/E and Esprit 120. I already have 2, T-2 prism diagonals. As I have some Naglers (7,9,16, 22) I was wondering if one of use had any experience with this combination.
I was thinking of getting another 16mm to use/start with.
#2 denis0007dl
denis0007dl
    Binoviewers Expert
  • Loc: Umag, Croatia, Europe
Posted 20 October 2020 - 10:12 AM
Naglers 16mm T5 are my favorite Naglers, and I love them a lot.
I only wish they have bit more eye releaf, but contrast and sharpness are excellent, and very compact size!
I like all other Naglers T6 in binoviewers as well.
Kind regards
Denis
#3 Kutno
Kutno
Posted 20 October 2020 - 10:17 AM
Have had wonderful experience with 16mm Type 5 Naglers in a Tele Vue Bino Vue, with a 10" f/5 Teeter Dob.
#4 noisejammer
noisejammer
    Fish Slapper
  • Loc: The Uncanny Valley
Posted 20 October 2020 - 12:59 PM
I have a pair of 16T5's and some T6's. They're great in my Mk V's. Back focus requirements are no different from the 24Pan or many Plossls.
Since the MB2 uses the same (or very similar) ClickLock collet as the Mk V, their undercuts won't matter.
All that said, do you really want  / need 82o? (My) Binocular vision seems to max out around 65o.
#5 MrRoberts
MrRoberts
Posted 20 October 2020 - 02:12 PM
I really haven't decided on the plan for ep's yet. It was only that I already have the Naglers and therefore only need to buy the one. I have considered a pair of Panoptics (19mm?). $ is not the concern here.
#6 Eddgie
Eddgie
Posted 20 October 2020 - 02:34 PM
First of all, if the first experience was disappointing, it might be better to kind of explain what was disappointing about it.
But that is neither here nor there to your question.
Nalgers can work well, but if it is an eyepiece that requires you to tilt your head to take in the whole field, it will probably not prove satisfactory for binoviewing.  When you turn your head to one side of the other to see the edge of the field in an eyepiece you IPD changes and this will usually cause you to loose the exit pupil in the other eyepiece.
If on the other hand you can take in the entire field without having to move your head from side to side, this it should work Ok.  Since this is a function of both the observer and the each specific eyepiece it would be hard to tell you that it is going to work great.
  • noisejammer likes this
