SharpCap not stacking with Alt-Az mount
6 replies to this topic
#1 audioengr
audioengr
Posted 20 October 2020 - 01:06 PM
I don't have my wedge installed yet on my Evolution SCT, but got some images of M13 that were good.  Stacked fine in post-processing.  I tried to live-stack and SharpCap would not align/stack anything after frame 1.  Is it moving too much for SharpCap because of the Alt-Az mount or is it a histogram stretch issue?  The image was pretty dim and I didn't realize how to adjust the histogram.  I do now.
Edited by audioengr, 20 October 2020 - 01:07 PM.
#2 jrschmidt2
jrschmidt2
Posted 20 October 2020 - 01:10 PM
Check the star detection under the 'Alignment' tab (in Live Stack).  There you can adjust the start detection settings, check the number of detected stars, and also (optionally) highlight the stars that are being used for image alignment in the stacking process.  The 'Log' can also be useful in diagnosing what is going on and why the image may not be stacking.
#3 audioengr
audioengr
Posted 20 October 2020 - 01:30 PM
Perfect, thanks.
#4 Stelios
Stelios
  • Loc: West Hills, CA
Posted 20 October 2020 - 01:41 PM
Moving to EAA.
#5 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 20 October 2020 - 02:57 PM
How narrow was the field of view for M13? With some globulars there are not enough bright field stars for SharpCap to use for alignment. However, I have not had this problem with M13, so I suspect some other issue. As someone has already mentioned, check the log file Tab under livestacking, and it should mention for each sub the reason it won't stack.
#6 GazingOli
GazingOli
  • Loc: Stuttgart GERMANY
Posted 20 October 2020 - 06:30 PM
Did you subtract darks? This is also important for live-stacking.
CS.Oli
#7 goldtr8
goldtr8
Posted 21 October 2020 - 05:52 AM
CS.Oli
That's what I was going to say, need to subtract darks.
