ZWO ASI294MC-Pro in hi-res mode gives only monochrome
3 replies to this topic
#1 audioengr
audioengr
Posted 22 October 2020 - 04:31 PM
I used SharpCap last night to get color images of M33.  I took flats and darks at 2 minute exposure.  I set the camera mode to 16-bit for the first time, which selects 14-bit mode.  The captures I find this morning are all monochrome, not color. There is also a tiny grid pattern on the low-level details in the photo.
I am testing this by capturing terrestrial images today with SharpCap with no flats or darks and they are in color on the screen, but when I take a "snapshot" and look at the PNG or TIF file, it's monochrome and has the grid pattern in the lighter areas.  I think I have tried all of the settings on the right hand side and nothing changes it to color.
I recently did a sensor analysis for this camera.  Could it be that went awry somehow?
Prior to doing the sensor analysis, I was getting color images using 10-bit mode.
Also, when I take flats, it asks whether I want a monochrome flat frame.  Should this be checked for a color camera?
Also asks "capture and subtract bias frames" - should I check this one?
Edited by audioengr, 22 October 2020 - 04:36 PM.
#2 John Rogers
John Rogers
Posted 22 October 2020 - 04:40 PM
I believe that SharpCap is saving the files in a raw format, so the colors are contained in separate layers.  You need to open the file with a program that will "debayer" the image correctly.
  • Midnight Dan and khobar like this
#3 audioengr
audioengr
Posted 22 October 2020 - 04:59 PM
Okay.  Looks like Autostakkert debayers it automatically when you have lots of subs.  Since I am only trying to debayer a single frame, I need to use something else.  Thanks.
#4 BinoGuy
BinoGuy
  • Loc: Michigan
Posted 22 October 2020 - 06:50 PM
Try Siril, it can debated single frames.
Clear skies,  BG. {°¿°}
