DobStuff Comments - Building from the Kit and Using in the Field
DIY dob
48 replies to this topic
#26 lphilpot
lphilpot
  • Loc: Central Lousiana, USA
Posted 24 October 2020 - 12:15 PM
If there's a particular image or two you're interested in, I can link them here...
#27 brentknight
brentknight
  • Loc: Foley, Alabama
Posted 24 October 2020 - 02:26 PM
Yes that's it in the profile pic.  I think it moves great in alt/az, very smooth - better than my lightbridge or es. No problems at all tracking - but highest power used was 5mm Nagler.  So that's x 340 approx.  You get what you pay for.  I have friends in the club with premium dob scopes that I've used - not just looked through.  It's not obsession or starstructure but it's half the price or less.  About the only issue is when I take out or put in the 31N I need to move the counterweight that is on a strut.  Where the counterweight needs to go depends on the angle of the scope.  I don't always find the sweet spot.  Also, I do have some collimation shift when moving the scope in alt\az.  Every mass produced dob I've owned before had some collimation shift.  It's less with the dobstuff but it's there.  Maybe a few MM with a laser when I tested.  But now I use a cheshire and sight tube mostly.   I've had commercial mass produced dobs where the return beam shifted almost out of the crosshair window in the laser collimator when checking this and those were truss.   So I am very pleased with this compared to the scopes this replaced. I don't go around with my laser at star parties and check my club mates Obessions and Starstructurers for collimation shift so I don't know what or how much is acceptable?  Maybe it's a deal breaker for some.  Obviously the 'flex' it's there when or if I look really low.  Usually, I have to refocus a hair if I move the scope a great difference in alt\az..  To me the weight savings is worth it and the views are still ok because I mostly look at galaxies and globulars with the scope and the collimation is 'good enough' for me.  If I wanted a stiffer scope I would go with the double ring and trusses, but "for me" I am happy with the struts\single ring and the scope weighs under 50lbs (I have a thinner mirror too).
As far as changes, issues:
#1  Spend the money and get the struts or trusses powder coated black - I did not and due to sometimes traffic lights (rare where I live) I get reflections off the silver struts.
#2 Well let me just say FIRST Dennis did me right so what I say next is not a complaint about my scope:  I was a bit concerned about the optics originally. It's a Coulter 13.1 mirror and I knew what I was getting into with that so NO blame what so ever towards Dennis even though he sold me the mirror.  No history on the mirror but it had new coatings.  I had a lot of problems in the beginning and some NOT so great views and I do have a Paracorr2.  I am talking astigmatic stars and the views were so bad that my 80mm ED put up nicer planetary images (last year).  Luckily I have some good club mates and I narrowed my visual problems down to #1 running my secondary dew heater too hot causing astigmatism  #2 My laser is out of collimation   So once I got that figured out everything is fine - I am getting pinpoint stars with my P2 and just wonderful sharp planetary views this season so far.
The last thing and this is a compliment - I "think" I should have had Dennis build me a bigger scope cause this is so easy to setup.  I "think" if I could have done it over I would have tried to score a 15 or 16 mirror and have Dennis build me a scope.  That's really my only regret - "I think".  But when talking with Dennis I told him I wanted the biggest scope I could be seated with and want to haul out every night and he delivered.  It's really a perfect size 'for me" hassle factor and all no matter what "I think".
good luck with a decision
cheers
k
Thanks much for your comments.  That's the kind of feedback I was hoping for.
My first telescope was the original Coulter Odyssey I 13.1" with the baby-blue mount.  Talk about a beast of a telescope - but I had a blast with it...
  • iKMN and Eliserpens like this
#28 brentknight
brentknight
Posted 27 October 2020 - 01:21 PM
Any that show mods that you did to the base would be great.
This is all I'm keeping from the XX14g...
Dennis is already working on the new rocker and bearings...
Side bearings and attachments to the existing tube..
Edited by brentknight, 27 October 2020 - 04:31 PM.
  • Jon Isaacs, cuzimthedad, Tyson M and 2 others like this
#29 lphilpot
lphilpot
Posted 27 October 2020 - 05:30 PM
Here are a few, not all will apply directly to your setup though.
I added a powered ground board, so the thickness of the stainless steel contact rings meant I needed to raise the Teflon pads by an equal amount:
I fed the power through to a PowerPole connector:
I also insulated over the bare contact points. Before the powered ground board, I had made a battery shelf for the rocker box, but that was too much off-axis weight to work well on my EQ platform:
I made a stop plate so the OTA wouldn't slam too far down:
I rounded over the altitude bearing points to protect my Telegizmo's cover:
I replaced the little furniture slider feet with hockey pucks:
I added a mirror fan:
I made a top mirror cover / lid. This is easier to put on, half asleep at 3 AM. Plus it gives a little transport space for lightweight / soft stuff (towels, etc.) when both lids are in place:
Added a board to mount my DewBuster on the altitude bearing:
...and painted the front / inside of the mirror board black:
  • brentknight, makeitso and Eliserpens like this
#30 brentknight
brentknight
Posted 27 October 2020 - 05:42 PM
Thanks Len. I’m wondering what you gained by swapping the feet out for hockey pucks?
#31 lphilpot
lphilpot
Posted 27 October 2020 - 05:46 PM
Stability. If the ground isn't perfectly level the scope would rock. The glides were only about 3/10" tall, so there was little clearance and we have lots of thick St. Augustine grass where I live. Plus the larger contact area of the puck adds to stability. The glides were about 1" across. It also keeps the ground board a little more above the dewey ground.
  • brentknight and Eliserpens like this
#32 brentknight
brentknight
Posted 27 October 2020 - 05:54 PM
I tried hockey pucks on my 10” Dob, but noticed the whole thing was much more sensitive to vibrations. I actually think the problem was more the placement of the pucks. If they are not right under the Teflon it decreases the stability. I might try them again on this mount. It sounds like it would really help when I take it to the woods...
#33 lphilpot
lphilpot
Posted 27 October 2020 - 07:59 PM
I attached them with contact cement, works great for me.
  • brentknight likes this
#34 brentknight
brentknight
Posted 07 November 2020 - 08:48 PM
Finished the Dobstuff rebuild of the Orion.  I think it dropped 70 lbs and 7" at zenith.  So far I'm very happy with the new mount and all the support and great kit from Dennis.
The old Orion Go2 mount.
I would never do this for real, but that's a good bit of weight on the end, and with the brake applied it does not drop and I can still move the tube.  No extra weight added.
The family portrait.  10" F6 on the left, AT102ED center and the 14" XX14g on the right.
  • Bill Jensen, Alterf, cuzimthedad and 7 others like this
#35 dob dude
dob dude
Posted 24 December 2020 - 12:29 AM
 hi i have an xx14 also and i am considering doing the same thing you have done with yours . but i was wondering if you have an orion carrying case and if you do does it still fit in the bag with the big new bearings and can it be zipped up? thanks
#36 brentknight
brentknight
Posted 24 December 2020 - 10:07 AM
I do have the cases and the lower tube fits just fine, but does not quite completely zip up (I have to leave one side mostly open).  I can still cover the top and use the handles to lug it around though.
I'm still very happy with the build and I've made a few modifications, but if I were to do it again, I'd try to get slightly larger trunnions from Dennis to mitigate some of the lingering balance issues.  Mine are 12", but I think 14" would fit without getting in the way of the truss attachments.  I'd also consider going with the half-round style instead of the full round as that would likely help some with getting the lower tube in the bag.  In the pictures above, you can see the head of the long bolt that attaches the trunnion to the tube.  I would think if there was a circle of wood around this bolt (for support), but the remaining top half of the trunnion was removed, things would still work.
#37 dob dude
dob dude
Posted 24 December 2020 - 01:10 PM
Thank you ! I am surprised that you are still having balance issues with those big bearings are you using all of your counter weights? mine came with 6 but mine is a intelliscope version and with the stock version I did not seem to have balance issues. Does the brake for the altitude help that much? And as far as the bag I pretty much felt that is how it would fit I suppose it exposes about a 2" gap or so on that side. Thanks again great looking set up there.
  Tim Fling
#38 brentknight
brentknight
Posted 24 December 2020 - 01:32 PM
Significantly better than it was with the original base, but heavy eyepieces (with the Paracorr) below about 30° it tends to nose dive.  With the brake, it does prevent the drop but I was just hoping I wouldn't need that.  If the trunnions were move a little more forward (toward the eyepiece end) I think that would help as well, but that's not really possible with the stock tube assembly.
If you end up doing the rebuild, I'd love to see your results...
#39 stargazer193857
stargazer193857
  • Loc: Southern Idaho
Posted 24 December 2020 - 01:57 PM
Wow. The new bases look so much more portable. And pretty.
Also, even though 10" is less aperture than 14", they look similar size and similar portability.
Edited by stargazer193857, 24 December 2020 - 02:07 PM.
#40 chaoscosmos
chaoscosmos
  • Loc: Mission Viejo CA
Posted 01 February 2021 - 12:20 PM
I’ve exchanged a few emails with Dennis recently re him building me a 10 or 12 inch scope. My back has been a little sore mounting a 120 EON on a DM6 so he suggests the 10. He says a truss is unnecessary but I think maybe the scope should have a shroud because of occasional stray light from my neighbors, and I’m imagining a shroud wouldn’t work with 3 truss poles, even if he also uses strings.
I think an upper cage might be best as well, but that seems to be going out of vogue. Maybe a shield for the primary mirror and upper cage would be sufficient without a shroud? I just wonder if a shroud would best insure optimum views.
#41 stargazer193857
stargazer193857
Posted 01 February 2021 - 02:15 PM
I also love how Dennis leaves the plies exposed. No need to spend time covering them when you can show off the quality plies. It emboldens me to do the same.
Looking at the 14" next to the 10", it really does ask how important f6 is. I'm thinking the 10" is for planets at home, and the 14" is for dso at a dark sky site.
Edited by stargazer193857, 01 February 2021 - 02:17 PM.
#42 brentknight
brentknight
Posted 01 February 2021 - 02:37 PM
I usually use my shroud, but it's mostly because I already have one and it's easy to use.
At a dark site, I think a shroud is less important.  From the house where ground level lights might be an issue, portable light shields that block those neighbors lights might be more effective.
I never liked the idea of an upper ring because of all the dew I deal with where I live.  Having just a ring would likely require active heating on the secondary to keep it dry.  An upper cage adds weight and bulk, so it's a trade-off.
Unless you have serious storage issues or you don't have a vehicle to transport the telescope, I still think a solid tube is a better option for a 10".  But then Dennis does not offer solid tube Dobsonians.  I would take one of his DobSTUFF Dobs over a commercial grade Dob any day though, and just figure out how to make it work.
#43 Bill Jensen
Bill Jensen
  • Loc: Springfield VA
Posted 01 February 2021 - 03:05 PM
One nice thing about keeping a shroud on is it limits the potential of something dropping on the objective, especially for any public observing with kids.
I like my 10 inch  solid tube for my bright backyard environment in the 'burbs of DC. Not only helps limit the dew issue in our midAtlantic summers but improves the contrast.
the shroud on my 16 inch truss is quite strong, and gives me a lot of comfort allowing folks to share the eyepiece (at least pre-Covid) at our star party.
#44 chaoscosmos
chaoscosmos
Posted 01 February 2021 - 03:48 PM
I'm just not sure about wrapping my arms around a 30 pound tube to lift it onto the rocker box. 5 years ago, maybe.
Dennis lists sample weights of various scopes on his website, but breaks down the components differently on each. On a 10 inch f/4.5 he lists the weight of the rocker box at 15 lbs and the telescope 39 lbs. I don't know for sure if "telescope" there means the entire rig or the OTA. On another size scope he lists weight of the OTA, and on another the weight of the mirror box.
I understand these are samples because specific weights depend on a number of factors, like mirror thickness.
Edited by chaoscosmos, 01 February 2021 - 03:50 PM.
  • stargazer193857 likes this
#45 Will_S
Will_S
  • Loc: Santa Cruz, CA
Posted 01 February 2021 - 10:12 PM
The OTA of my 13.1" Dobstuff (1" thick Coulter mirror) weighs 42 lbs, so 39 lbs seems pretty heavy for a 10" OTA.
#46 brentknight
brentknight
Posted 01 February 2021 - 10:59 PM
The Orion SkyLine 10" solid-tube Dobsonian OTA weighs 34 lbs.  It's not unusual for a truss Dobsonian to weigh more than a solid tube, so 39 lbs. sounds reasonable for the OTA.
If the telescope will live in the garage or somewhere near the observing site, then the weight isn't really an issue.  I wheel the 14" out with a hand-truck and never have to lift that weight.  For transport in a vehicle, the separate pieces will weigh much less.
  • Bill Jensen likes this
#47 chaoscosmos
chaoscosmos
Posted 02 February 2021 - 12:23 AM
With a tube there’s nothing to grab onto, except I would think to pick it up by the bottom. Can you grab the struts or trusses on a 10”, or no? I’d guess you’d pick up from the lower portion of the scope as well.
#48 stargazer193857
stargazer193857
Posted 02 February 2021 - 02:38 AM
One hand grabs the edge of the lower portion. Scope leans against other arm. Base moved separately.
#49 Bill Jensen
Bill Jensen
Posted 02 February 2021 - 07:17 AM
It depends on the tube model telescope. If you have one with a cradle, it can often be picked up using it or the attached bearings which are large in the case of my Teeter.
I also purchased (but don't use) Velcro brand strap handles. for a mass market dob that doesn't have a tube cradle, you can purchase strap a handles, or the similar velcro style straps for either side of the bearing. Makes carrying the OTA much easier. If you do a search on strap a handle telescope tube or some similar search terms, you will see quite a few examples. I think Farpoint and Astronomy-shoppe also sell some straps designed for the proper size of scope (although a bit more expensive as I recall). My straps cost less than $15 at Lowes at the time.
Also tagged with one or more of these keywords: DIY, dob
