Restoration of Meade 8" Newtonian
beginner classic DIY dslr Meade mount reflector 3d printing
7 replies to this topic
#1 Squidink
Squidink
  • Loc: Greater Boston
Posted 22 October 2020 - 09:06 PM
I got a 8" Meade newt off Craigslist. It needs some restoration and I will document it here.
I think it's a 1990s vintage F/6. But I can't positively ID it yet.
It came on tripod with die cast legs and a 4" tube, like my MTS-6SN. Only on a plywood trolley with casters
Features:
Battery operated RA motor drive, but no fine adjuster. Appears to take a 9V, but has an adapter for 6x AA batteries. Also has a jack for 12V. It seems to work, but clutch engagement/disengagement is a mystery.
Rust. It was stored on a 3 season porch.
Pollen. See above.
The world's worst focuser- a 2" rack and pinion with stripped teeth.
Finder scope: 6x30mm straight through.
Thermoformed  end rings on old, repainted sonotube with mildew stains and a overspray of white.
A 2nd set of mounting holes for the mirror for (D)SLR focus.
What to do:
It needs a cleaning and focuser. Just for evaluation. Or at least a cleaning.
If it is what I think it is, I will press it into light AP duty with a DSLR.
I am wondering about a fiberglass overcoat on the Sonotube
Your input is welcomed, this is my first try.
IMG_7720 (1).jpg IMG_7721 (1).jpg IMG_7722 (1).jpg IMG_7724.jpg IMG_7714 (1).jpg IMG_7717 (1).jpg
  • Bomber Bob likes this
#2 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 23 October 2020 - 05:35 AM
Looks like a early 90's Starfinder. I had one and it was very good.
Edited by CHASLX200, 23 October 2020 - 05:35 AM.
#3 Macguyver909
Macguyver909
  • Loc: North West,WI
Posted 23 October 2020 - 10:16 AM
I agree on the early 90's starfinder. I have a DOB mounted one and the spider is exactly the same as yours.
Everything I have read about the early starfinders, is that they have surprisingly good mirrors. I put a GSO focuser on mine and moved the focuser and spider up, and the focuser to the opposite side for right eye dominant viewing. It will reach focus with a mirrorless Sony camera with this setup ( 24mm back focus vs ~ 54mm for a mirror camera). Just a FYI, after the new focuser, I had to shim the focuser base to get collimation to agree between a cap and laser.
Also added a RACI finder.  Looks like yours has a better mirror cell. Mine is the RTV to particle board type.
A good coat of bondo skim coat on the tube and white appliance paint will do wonders for the tube, I would skip the fiberglass.
Put a fan behind the mirror, the mirrors are thick and need all the thermal management they can get. Flock it and Rock it!!
I paid $100 for mine and as a total newb, wasn't afraid to hack and wack. I'm glad I did, it turned out to be a very usable instrument.
#4 Squidink
Squidink
Posted 23 October 2020 - 05:59 PM
I found a thread noting that the secondary mirror may be undersized on some of these starfinders.
https://www.cloudyni...e-starfinder-8/
I am not 100% clear on how I determine this.
I did find a pollen coated marking on the back of the mirror. If it's an 8" primary, that makes this just shy of f/6.
#5 Squidink
Squidink
Posted 26 October 2020 - 06:33 PM
I have a crazy idea. I am going to pursue it a bit.
I have a 2' x 4' sheet of polypropylene honeycomb cored fiberglass. If I slit it half depth 5 time to get (6) 6" x 48" flats, I could get a hexagon with a 9.8" distance across the flats, inside to inside. (right? 2x SIN(60degrees)) With a little resin and tape, it would have great damping, flat sides and hold an 8" mirror cell. Maybe I can stretch this to 10" ID. I am not sure of the true ID of moldy 10" sonotube is. I will grab some calipers.
#6 rsnuke
rsnuke
Posted 30 October 2020 - 11:12 PM
The original 2" focuser is garbage, I've had a 8" since '97, and those teeth strip off... I do recommend changing it. 50-100$ for one.
  • Squidink likes this
#7 Squidink
Squidink
Posted 02 November 2020 - 09:26 PM
I should be receiving one in a week from the classifieds here. Yeah, the teeth are coming off. I was astounded! Good to know the optics are good. That's something I keep hearing. There isn't a whole lot else to recommend, given the construction and condition.
#8 Squidink
Squidink
Posted 21 November 2020 - 09:52 PM
This has been on pause for a week while other chores get completed.  I now have a focuser and new aluminum end rings. The pollen is off the secondary. I still need to clean teh pollen off the primary.
I have a question though.
I have a 3.2mm FL Paradigm ED eyepiece. That's still too short a FL for even this scope. It should gather rather more light, but with f/6, the exit pupil will be just over .5mm, right? So It will be not so much fun, I guess?
Also tagged with one or more of these keywords: beginner, classic, DIY, dslr, Meade, mount, reflector, 3d printing
