Frost on concrete pier
3 replies to this topic
#1 bouvier_1
bouvier_1
  • Loc: Sundre, Alberta
Posted 25 October 2020 - 05:34 PM
I notice that frost is forming on my pier inside my Skyshed Pod. There is about 3' of exposed pier under my deck. I am not heating the Pod but solar is warming the interior during the day.
Is this something others have noticed?
Is this something of concern?
Is there any mitigation needed?
Thanks for any input. This is my 1st winter with the Pod.
#2 macdonjh
macdonjh
Posted 25 October 2020 - 07:06 PM
I wouldn't worry about frost on your pier from a structural standpoint.  Unless there is a crack the water could work into and then freeze.  Cracks should be filled with something.
#3 speedster
speedster
  • Loc: Abilene, Texas
Posted 26 October 2020 - 02:15 PM
I would be concerned but not about the pier.  Water vapor has to condense to form frost which means your pier is below the dew point.  Is the mount and scope far behind?    A small heater will take care of it.  So that you are no trying to heat your whole back yard, you can seal the gap between dome and walls.  Some say 3/4" backer rod will work but it wasn't thick enough for mine.  I tried several things and garage door weather seal worked best by far.  It's in place permanently and does not add noticeable friction to dome rotation.  It also keeps out bugs and other critters.
  • laedco58 likes this
#4 bouvier_1
bouvier_1
Posted 26 October 2020 - 02:39 PM
I've seen your weather seal solution before and I fully intend on doing the same.
It's such a good idea it should be incorporated into the new ones!
Edited by bouvier_1, 26 October 2020 - 02:44 PM.
