So if I buy the Baader 35nm recommended by BYoesle that kind of makes the blocking filter in the Quark redundant? Because the other harmonics will already have been blocked
NO ABSOLUTELY NOT!!! The diagram posted by David is a very simplistic view of an H alpha filter system, and in NO WAY represents a real filter system!
The Baader 35nm filter is acting as an internal sub-diameter ERF (as an alternative to an internal sub-diameter UV/IR filter ERF) - NOT A BLOCKING FILTER! The blocking filter itself has an order selection filter usually with a bandpass only 6-10 Angstroms wide, along with additional UV and IR blocking. The Baader 35 nm H alpha filter has a 350 Angstrom bandpass, and will have no long-IR blocking!
The free spectral range (FSR) is the distance between the etalon harmonic peaks. The blocking filter contains an order selection filter that has a bandpass narrow enough to block off-band harmonic peaks, only allowing the peak of interest through and blocking the others:
David: You may also want to modify your diagram by combining "changing the plate mirror spacing" and "changing the temperature of the filter," which are essentially the same thing. The third way is to change the refractive index of the etalon gap, which is commercially done by changing the air pressure inside the etalon chamber.
I am almost going to buy a filter that i hope it is the right filter to be as ERF or blocking filter whatever, but i think i can't do the same with CaK or call it K-Line filter then.
That is correct, but it is not a "ERF or Blocking filter whatever."
Listen up everyone. If you don't fully understand what these filters are called, what these filters do, and where they need to be placed, you shouldn't be mucking around with these systems in the first place.
The ERF for a H alpha filter generally will block UV at 394 nm, and will therefore not work for CaK or K line use. In that case you'd need a KG3 filter for IR blocking, and a 400nm + short-pass filter.
Edited by BYoesle, 11 March 2022 - 06:58 PM.
