Trouble with Stallerium and EQMOD
1 reply to this topic
#1 bluesilver
bluesilver
Posted 29 October 2020 - 01:43 AM
Hi,  I have a few dramas that i am hoping a few might be able to help me out with.
So I have Stallerium and EQMOD
I am also in the Southern hemisphere  and in Australia
Mount is a Skywatcher EZ-EQ6,  the newer one with the USB B port on the mount.
The first issue is do do with Stallerium.
When i go to connect telescope,  i get the connected,  so all good there,
Close off the window and try to find where my mount is pointing.
50% of the time the mount icon is pointing in the grass roughly SE,  the other 50% of the time it appears to be pointing at the SCP
So not sure what is going on there.
I have set my location as spot on manually as i can,  ( am i best just to select a town from the drop down list instead ?)
I changed the time to UTC +10:00 as this is what i believe is the correct time zone for Australia
Dose any of this sound incorrect or explain why the telescope is showing pointing into the grass at roughly SE once connected?
I have the telescope set  up so that home position is pointing at the SCP
Now in EQMOD tool box,
I have the Baurd set at 115200
I have entered the location as it is on Stallerium so that both are the same
For polar star i selected Sigma O  ( i think this is correct ?)
Now this is the interesting part i guess.
I took note of the RA, DEC, AZ, ALT numbers on both Stallerium and EQMOD and noticed that they were all different.
I am fairly sure this could be part of my drama.
Also noted on EQMOD that the LST  ( i am not sure what this is,  maybe local standard time ?)  This didn't match the time in Stallerium or the laptop
This is what i had from EQMOD and Satllerium
EQMOD                                        Stallerium
LST   18:09                                   16:51 ( on Laptop )
RA     3.47:19                                 3h 47 14.89s
DEC  -74:04:50                              -74 10' 32.8"
AZ     169:30 :30                             169 32' 20
ALT   27:51 :50                               27 57:00
Note:  this is not the home position numbers,  i selected a star slightly away from the SCP to see if i could get some better numbers to try and make it easier to understand what is going on.
( telescope slewed to this star )
Also when i click on LST in EQMOD,  it changes to AM 1.568
Sorry for the long post,  but any advice or information on what might be going on would be appreciated.
I do have APT  but don't want to confuse the question with tis as APT settings did match EQMOD .
All advice and information is appreciated.
Thanks.
Edited by bluesilver, 29 October 2020 - 02:13 AM.
#2 PirateMike
PirateMike
  • Loc: A Green Dot On A Blue Sea
Posted 29 October 2020 - 04:59 AM
LST is local sidereal time... which is the angle hour at the merdian.
I can't really help you with using Stellarium to control your scope... but did you save the setup?
Have you tried Cartes du Ciel? It's not as pretty as Stellarium but it does work wonderfully with EQMod. https://sourceforge....jects/skychart/
Miguel   8-)
