Greetings all,
Over the past year I have done a lot of research into multi-narrowband filters, such as the OPT Radian Triad or Optolong L-eXtreme. Through that work I have been made aware of an issue with trying to use narrow band pass filters on fast optics such as the Celestron RASA or SCT's with Starizona's Hyperstar system. To get a better understanding of the problem I did an analysis using a set of generic H-alpha filters, ranging in bandwidth from 40nm down to 1nm. I predicted how these filters would impact the performance of an 8" RASA telescope (f/2), as well as a 4" refractor of the same focal length (f/4). The attached plot below is one of the main results from my analysis. Because the pass band of the filters shift with the angle of the light passing through them, the filters act essentially like an aperture mask. The narrower the filter, the more restrictive the mask. This effect is very pronounced on a RASA scope because of the large central obstruction. In fact, based on my calculations, you are much better off using the 4" refractor if you intend to use filters narrower than 6.5nm. You can read my whole article on the matter at the link below.
http://karmalimbo.co...ics_Nov2020.pdf
Best Regards,
Jim T.
