Do you Feather Touch your Takahashi?
113 replies to this topic
#101 tboss70
tboss70
  • Loc: Missouri
Posted 22 November 2020 - 04:16 PM
awesome, thanks rkelley8493.  I think you are right after checking again:
Micro Pinion Assembly Takahashi Retrofit, 2.5" Diameter Telescope Focusers (fits Takahashi Sky 90, FCL-90 Telescopes, and FC 100)
Edited by tboss70, 22 November 2020 - 04:21 PM.
  • rkelley8493 likes this
#102 25585
25585
Posted 23 November 2020 - 08:04 AM
DZ uses the same focuser as DF & DL, the 2.5".   TSA models need the 2.7".
  • tboss70 and rkelley8493 like this
#103 tboss70
tboss70
  • Loc: Missouri
Posted 23 November 2020 - 10:10 AM
I guess what confused me is the Tak America page says:
"The FC-100DZ utilizes the same focuser used on the FC-100DF and DL and weighs approximately 3.8 kg."
and the DF page says "The FC-100DF is optically identical to the DC model, but features an enhanced 2.7 –inch focuser"
  • 25585 and rkelley8493 like this
#104 rkelley8493
rkelley8493
  • Loc: The Emerald Coast
Posted 23 November 2020 - 12:33 PM
That's what threw me off as well.. A few Cloudy Nighters informed me about it actually being 2.5", otherwise I wouldn't have known.
Another curve ball, Starlight lists the 2.7 MPA as being compatible with the FC100, but I think they're referring to the older model (not the DF, DZ, or DC).
Edited by rkelley8493, 23 November 2020 - 01:41 PM.
  • tboss70, RAKing and 25585 like this
#105 tboss70
tboss70
  • Loc: Missouri
Posted 23 November 2020 - 01:14 PM
Again, thanks all. I need to read back through the thread but does anyone use an electronic focuser? I think in my case if I got the MPA-TAK2.5 it would be this:  https://starlightins...&product_id=475
Just curious since these are ASCOM compliant can they be controlled via software for autofocus like with SharpCap while you are imaging? Or is it more like you have to check it every hour or so?
#106 RAKing
RAKing
  • Loc: West of the D.C. Nebula
Posted 23 November 2020 - 02:14 PM
They are.
I also got fouled up with the newer 95mm FC-100 series and thought my 2.7" stuff would work.  It didn't and I had to scrounge around for some Sky 90 fittings and things to make the scope work for me.
The lenses are just as good with the new scopes and I guess that's the important thing to remember.
Ron
#107 25585
25585
Posted 24 November 2020 - 04:38 AM
All this confusion could be sorted if Takahashi actually updated and modernised their web site.
When buying the extenders, my dealer contacted Tak Europe (also outdated), who in turn had to email contact Tak Japan for the correct model.
  • RAKing likes this
#108 rkelley8493
rkelley8493
Posted 26 November 2020 - 12:15 AM
My former Tak Mewlon 210.  Yeah, I know it’s not a refractor, but since the topic was about Taks with FeatherTouches...
Scott, would you mind elaborating on how you setup this Feather Touch to your Mu 210 and what model FTF it was? I've been thinking about getting this scope and like the idea of outfitting it with this type of focuser.
#109 213Cobra
213Cobra
  • Loc: Los Angeles, California, USA
Posted 26 November 2020 - 04:53 AM
FT pinion microfocuser on Takahashi Epsilon 160.
  • Scott in NC, noisejammer, RAKing and 4 others like this
#110 Scott in NC
Scott in NC
    Refractor Fanatic
  • Loc: NC
Posted 26 November 2020 - 09:37 AM
This was a few years ago, but I believe that I bought the adapter directly from Starlight Instruments (you just have to find the correct one for the scope on their online catalog, as they make adapters for a multitude of different scopes).  I believe it cost somewhere around $75.  You’ll want a FeatherTouch with a short draw tube, but I can’t remember right now whether I used one with a 0.8” draw tube or a 1.5” draw tube.  I bought a used FT focuser from a fellow CN’er, RAKing.  Possibly he remembers and will chime in here.
  • payner and rkelley8493 like this
#111 payner
payner
  • Loc: Bluegrass & Cumberland Valley Regions, Kentucky
Posted 26 November 2020 - 02:31 PM
As Scott noted, get the correct adapter (A20-261 for the 210 ($115 new)) and I'd purchase the 2015BCR ($515 new) for the 210 Mewlon. You  can always keep an eye out for used and save.
  • Scott in NC, RAKing and rkelley8493 like this
#112 Scott in NC
Scott in NC
    Refractor Fanatic
  • Loc: NC
Posted 26 November 2020 - 03:28 PM
Yeah, maybe the adapter was really $115 and not $75, or maybe the price has gone up over the past few years.  But it’s the focuser that’s the really pricey item.  Unless you really want a brand new focuser, or must have it right away, I’d recommend waiting to see if one shows up on the used market, and you’ll likely save a couple hundred bucks.  People list these on AM and CN Classifieds all the time.
#113 gjanke
gjanke
Posted 26 November 2020 - 03:56 PM
I tricked out both my TSA’s with with the 3035 focusers. I managed to get both sets used save for a couple of pieces I got from SL and the was still $1700. About the price of a nice used  4” Tak ED. However Scott’s right I saved about 300 bucks per focuser.
I just put a want ad out and I had two responses. The trick is making sure you get the right parts and adapters necessary or it could be an expensive lesson in attention to detail.
I bought the scopes used and sold the micro focusers from both so that off set the cost as well. However if and when I do sel these scopes...more likely when the SL focusers are going with each one.
#114 Dougal
Dougal
  • Loc: NC
Posted 26 November 2020 - 11:49 PM
FTF 3035 has been a joy to use and makes this great scope even better. The stock focuser was by no means bad, but I did notice  some image-shift at higher powers and I could never quite adjust it to the smoothness and stability I wanted. FT upgrade was totally worth it for me, especially because I use a heavy Binoviewer for planetary with this scope.
My former FS-128.  You can just barely see the FTF 3035 3” focuser at the back end.  Sorry I don’t have a better image of the focuser handy.
  • Scott in NC, Phil Cowell, RAKing and 3 others like this
