Zeiss Asiola Objective Glue Concern
19 replies to this topic
#1 SandyHouTex
SandyHouTex
  • Loc: Houston, Texas, USA
Posted 10 November 2020 - 09:58 PM
So I just received a very nice Asiola with a Zeiss Jena 10mm Ortho, the leather case, and the alt-az connection to the mount.  If anyone has the mount part, or know what I can use, please let me know.
It’s in really nice shape.  No dents or dings.  The objective looks nice, and when I put the 10mm in it and focused on a porch light tonight, the image looked very sharp.  No issues I could see.  The objective is also a #1 quality.
My concern is the glue in the objective.  I’m pretty sure they use the same glue as Telementors and Telematers (sp.?).  Is there a concern about that?  Did ZEISS use Canadium Balsam?
Also what can be done with the exterior covering?  It’s in decent shape, but I would like to return it to it’s original condition.  Is it leather?
I appreciate any help you can offer.
Edited by SandyHouTex, 10 November 2020 - 10:02 PM.
#2 Bowlerhat
Bowlerhat
  • Loc: Melbourne, Australia
Posted 11 November 2020 - 12:48 AM
Asiola kit:
https://www.ebay.de/itm/193730366776
Asiola, tripod only:
https://www.ebay.de/itm/114507257415
I think asiola is older than telementor/telemator when they started using the cemented cells.
It is leather, yes.
#3 SandyHouTex
SandyHouTex
Posted 11 November 2020 - 10:59 AM
Asiola kit:
It is leather, yes.
Thanks.
#4 RichA
RichA
  • Loc: Toronto, Canada
Posted 11 November 2020 - 09:21 PM
Zeiss microscope objectives from back when are rife with problems like delamination.
#5 SandyHouTex
SandyHouTex
Posted 11 November 2020 - 10:40 PM
Are Telementors also rife with the problem?  I have not heard of any Telementor issues.
#6 strdst
strdst
  • Loc: Oregon Territory
Posted 12 November 2020 - 12:55 AM
I have a (type 1 ?) Telementor that was diagnosed here on CN years ago as having separation anxiety as the marks seem to be between the elements. The tube at the objective end is slightly out of round suggesting quite a smack occurred in the past. If you have a Telementor you know how thick the tube is! I suspect a hard knock may have affected the balsam. Looking through this instrument there is no suggestion of a problem though. Because of the out of roundness, removing the lens to re-cement or even clean it is impossible for me to do as the lens cell must be removed through the damaged tube with very little clearance frown.gif
#7 Bowlerhat
Bowlerhat
Posted 12 November 2020 - 01:46 AM
I think it's interesting that they use same standards in many applications. I saw an ad of  CZJ telescope which they use for flak cannons.. and it uses a CZJ orth x17 eyepiece. As I know it's a microscope eyepiece. It is definitely a tank.
Have you tried removing it? It should slides out https://www.cloudyni...move-lens-cell/
But at least with telementors, the lens cells are readily available now and then, there's one in amart right now. So it's possible to get a new cell. But I've never seen asiola's spares, it's much more uncommon.
#8 strdst
strdst
Posted 12 November 2020 - 02:37 AM
I'm pretty sure there isn't enough clearance to slide the cell out. It is quite well deformed!
#9 Bowlerhat
Bowlerhat
Posted 12 November 2020 - 02:53 AM
I wonder if the cell actually floats or there's a narrowed part or ledge that the lens sits on inside? If the tube is empty maybe you can push it to the other side from the front?
#10 Terra Nova
Terra Nova
  • Loc: Northern Kentucky
Posted 12 November 2020 - 09:21 AM
I’ve had two Telementor’s, a very early T1, and also a T2. Both of course, like all the others had C-type objectives, meaning they were cemented. I would assume Canadian Balsam was the cementing agent. They also had deep blue MgFcoatings. Neither had any issues whatsoever with either the cementing or the coatings.
#11 SandyHouTex
SandyHouTex
Posted 12 November 2020 - 10:11 AM
Thanks Terra.  That’s reassuring.
  • Terra Nova likes this
#12 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 12 November 2020 - 11:10 AM
Having had about 6 telementors and still having a few I have never seen an issue with the objective glue seperating.
  • SandyHouTex likes this
#13 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 12 November 2020 - 12:22 PM
you  might be able to round out the tube with a pipe expander
https://shop.advance...m=pipe expander
  • bremms likes this
#14 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 12 November 2020 - 12:25 PM
I would buy the tripod on Ebay.  The chances of finding another one is slim.   I have a few of these scopes and feel blessed I have all the parts.
#15 SandyHouTex
SandyHouTex
Posted 12 November 2020 - 08:50 PM
There’s one in Germany, but he won’t ship to the US.
Does the Telementor use the same tripod?
#16 Corcaroli78
Corcaroli78
  • Loc: 55N, 9E, Denmark
Posted 13 November 2020 - 05:54 AM
Telementor, Asiola and CZJ theodolites share the same tripod. If you look for the CZJ surveyor tripods, they are usually priced lower (despite being the same).
Regards
Carlos
  • SandyHouTex and Terra Nova like this
#17 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 13 November 2020 - 08:54 AM
Regards
Carlos
The tripod might look the same it is actually what goes on top of the tripod that makes the difference.  Without that part for the mount to slide on top of the tripod is useless.  There are also other differences that make it rather hard to interchange parts from different years.  Been there done that.
  • SandyHouTex and Bowlerhat like this
#18 Corcaroli78
Corcaroli78
Posted 13 November 2020 - 10:56 AM
You are right.
The spigot is not an element of the theodlite tripod.
#19 Piggyback
Piggyback
  • Loc: Germany
Posted 13 November 2020 - 11:39 AM
Asiola tripod not interchangeable with Telementor/Telemator. It is more lightweight and doesn`t come with spreaders.
  • Corcaroli78, SandyHouTex, Terra Nova and 2 others like this
#20 strdst
strdst
Posted 17 November 2020 - 12:20 AM
That looks like a nice one. My previous experience was with using a Harbor Freight expander on a much thinner walled telescope which removed the dent just as it pleated the outside of the tube. Might be worth a try. I've been adhering to "do no harm" on the Zeiss.
  • Piggyback likes this
