Lens diameter from Yerkes to LSST telescope?!
2 replies to this topic
#1 Lucullus
Lucullus
Posted 22 November 2020 - 07:18 AM
I read that the largest lens diameter of the LSST is 1.55m. Up to now, I knew that the largest lens was 1.25m for a stationary lens at the Paris 1900 Exhibition. The largest movable lens with similar atmospheric pressure environmental characteristics is the Yerkes telescope with 1.02m. There is the Swedish 1m Solar telescope with an aperture of 1.1m, stopped down to 98cm, but I don't take this as a reference point for the 1.55m LSST telescope and my question below because, as the Swedish Solar telescope information on their website explain, Solar telescopes are designed to handle the pressure differences inside the sealed tubes with either a vacuum or Helium inside. What I am interested in are similar pressure levels all around the lens, which I assume is valid for the LSST 1.55m and Yerkes 1.02m lenses.
OK, I am wondering how it was achieved to build the lens of the LSST so much larger than previous lenses which were hindered to be made larger by gravitational saging due to their own weight. What advances were made in glass material or lens support to jump from ~1m for a movable lens to ~1.5m without introducing obstruction?
#2 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 22 November 2020 - 07:50 AM
From what I've been explained by some optical designers, it was NOT gravitational sagging that made refractors larger than 40" impossible, but economics. Their domes and mounts simply need to be so gigantic, relative to the aperture, that making them didn't make sense from an economical point of view, once the reflector matured and became practical. Color correction would also be an issue, but the Schupmann medial could have solved that. What really gave the large refractor the death knell was the upcoming photographic technology. Here, the perfectly achromatic reflector had a HUGE advantage.
Clear skies!
Thomas, Denmark
#3 Jon Isaacs
Posted 22 November 2020 - 08:19 AM
As a point of reference:
The focal length of the Yerkes 40 inch is 760 inches, the Palomar 200 inch is 666 inches.
jon
