Dual threads
8 replies to this topic
#1 pcardinal42
pcardinal42
Posted 22 November 2020 - 10:14 AM
Looks like I need to do better research before purchasing. Snagged an L-extreme and figured it would be like other filters I've seen and the one I have that are threaded on both ends.
It only has a male thread that I can put in my T ring but then I can't attach anything after that. With other filters it would go camera, t ring, filter, flattener/reducer, telescope.
Is there any fix to this at all? Seems odd that Optlong only threads one side of a filter. How else do other people use these?
http://imgur.com/a/I54uy6d
Edited by pcardinal42, 22 November 2020 - 10:18 AM.
#2 DLuders
DLuders
  • Loc: Spokane, WA
Posted 22 November 2020 - 10:53 AM
You could look at the various "adapters" on ScopeStuff.  smile.gif   They probably have something that will work for your setup.
  • pcardinal42 likes this
#3 wrvond
wrvond
  • Loc: West Virginia
Posted 22 November 2020 - 10:55 AM
I've got a couple filters that only have the male thread. The only solution I've found is for visual use only - installed in the barrel of the diagonal or the eyepiece.
#4 pcardinal42
pcardinal42
Posted 22 November 2020 - 11:43 AM
Checking it out now thank you
#5 pcardinal42
pcardinal42
Posted 22 November 2020 - 11:44 AM
Unfortunately this is for imaging so unless I find a solution fast I'll be returning the filter for something else.
#6 SonnyE
SonnyE
  • Loc: Cali for ni a
Posted 22 November 2020 - 12:36 PM
Mine found it's place in my manual filter wheel (position 4), and has been performing great for me.
#7 pcardinal42
pcardinal42
Posted 22 November 2020 - 12:58 PM
I'm not quite at the level of needing a filter wheel. I just use a dslr and I'm wanting to upgrade to a color camera so probably still won't use a filter wheel.
#8 SonnyE
SonnyE
Posted 22 November 2020 - 06:04 PM
"I'm not quite at the level of needing a filter wheel. I just use a dslr and I'm wanting to upgrade to a color camera so probably still won't use a filter wheel."
You might eventually want a filter wheel though. I don't really use mine like most do. I tend to use it as a filter storage, and can crank my wanted filter into place. (Manual type wheel, OSC camera)
Maybe if you called where you got it they can offer a better idea. Or a different option.
Maybe even a snap in version for your Sony.
Mine is still very new to me, and it seems to still be attracting clouds like all new equipment does. lol.gif
#9 pcardinal42
pcardinal42
Posted 23 November 2020 - 08:07 PM
Found my solution. Just need to figure out how to unmount my filter so I can mount it back inside this..
https://www.baader-p...).html?___SID=U
  • wrvond likes this
