XT10 Plus replace tension pads possible?
#1
Posted 22 November 2020 - 12:23 PM
#2
Posted 22 November 2020 - 01:48 PM
Maybe put in a want ad for a used base....Orion may have some, but they mostly refuse to deal with anyone who is not the original buyer....maybe if the previous owner gave you the purchase receipt.
- bambroso likes this
#3
Posted 24 November 2020 - 01:05 AM
I have an XT8, not a 10, but comparing the pads to a PTFE sheet, the PTFE was more opaque and slicker. I think you would be fine if you replaced your pads with PTFE, in fact it would be the preferred material for that purpose. Most ATM dob bases seem to use it.
- Jon Isaacs likes this
#4
Posted 24 November 2020 - 12:24 PM
Yes, you can buy PTFE sheet or even pre-cut squares.
This will be superior to the nylon(If that is what is used and I think in some cases it is). It is an easy material to work with, so if you have to trim some, you can use a razor or hobby knife.
You can buy sheets from McMaster
https://www.mcmaster...y-ptfe-sheets/
