70" eyepiece height at zenith is my comfort max, feet on ground. So 14" F5 would be largest I would go for. Faster means more collimation preciseness & anxiety.
Downside to Dobsonians?
#101
Posted 31 December 2020 - 04:01 AM
#102
Posted 31 December 2020 - 04:14 AM
Preciseness of collimation and anxiety are easily solved, I use Penfolds Bin 389 or Bin 707 to soothe away any anxieties and OCDs while observing, works superbly well.....
- Lukes1040 likes this
#103
Posted 31 December 2020 - 05:42 AM
Collimation anxiety.
Perhaps try less caffeine?
#104
Posted 31 December 2020 - 05:51 AM
If I remember correctly, your scope is a 17.5 inch F/3.5. For someone 6 ft. tall, an 18 inch F/4 can be flat foot and with a Catsperch Pro, it can be a 100% sit down scope. I need no ladder with my 16 inch F/4.4 but it's right on the verge.
The ladder comes along with a larger scope.. With the right ladder and the right circumstances, there is no reason to be afraid of a ladder.. There was a time when I was considering reworking my 22 inch with sub F/4 mirror but I decided I would be wiser just to put the effort into improving the ladder.
- brentknight likes this
#105
Posted 31 December 2020 - 11:24 AM
Part of the problem with the current mass-produced Dobsonians is the size and shape of the ground board. From a logistical and physical viewpoint, round boards that extend out from the rocker box are just plain stupid. If using a chair or a small ladder with them, you are forced to sit too far away from the eyepiece at most angles. Square ground boards (or even triangular) eliminate most of this problem...
- izar187, Don H, Bomber Bob and 2 others like this
