As the title says, my 1600 MM-C Pro disconnects from USB when the DC power cable is plugged in. Unplugged and it reconnects and I can access the camera and devices attached to the USB hub. Once plugged in, everything disconnects. The fan on the cooler doesn't start up but the red LED does light up. This happens from DC power from either my dedicated battery or my pegasus powerbox advance plugged into AC power. I haven't changed anything about my setup, software, etc and this problem just started tonight (was going to practice some imaging grrr). Tried restarting to no avail. I also tried plugging the camera direct, tried without anything on the camera's hub, same result. Wondering if anyone else has had this issue -- and if you solved it? Thanks!
Edited by andrewenglish, 24 November 2020 - 10:03 PM.
