I'm trying to connect my new mount to PHD2 on a rainy day using the simulator. When I hook up the camera directly to the mount, the simulator will calibrate and work fine. When I hook up the mount to my computer with ASCOM, PHD2 will connect. However, it will not move the mount in calibration or guiding. Does anyone know if it should work both ways.
Does anyone have the process from scratch to hook the PC to the mount, then to PHD2, and then it works. I know the mount is connected because I can make it move in both EQMod and NINA. If important PHD2 is reading data from the mount, because it gave me a calibration error that the mount was not below 20 degrees dec. If you have a routine to share, please.
Edited by mic1970, 25 November 2020 - 02:31 PM.
