I go out to observe Jupiter and Saturn a few nights a week when it's clear out. Tonight, 11/26 I can see both of them in my 8x50 finder scope easily. With only 25 days away it will be interesting to see them getting closer and closer every night!.
They are getting close!
#2
Posted 27 November 2020 - 12:54 PM
I normally have to move the scope up and to left of Jupiter to center Saturn in my 9x50 finder scope. Not tonight. When I went to view Jupiter in the finder, I was surprised to see Saturn just above it in the finder! Wow, they moved quick this week! Not sure what the FOV is in the finder, anyone know, it's Orion 9x50 RAF.
- flt158 likes this
#3
Posted 27 November 2020 - 07:18 PM
I need to check this out, also. But right now we have rain & clouds. Well, mostly clouds. I cursed myself, getting larger equipment. Should have known what always happens!
Clear Skies,
Matt.
#4
Posted 27 November 2020 - 07:38 PM
I estimate (just by eye) that they are now about 2-1/2 degrees apart. Sky Safari says 2d 34m. Some very noticeable movement will take place in the next weeks.
- REC and flt158 like this
#5
Posted 28 November 2020 - 07:23 PM
Rain in the area, still. More than yesterday. It was a light mist this afternoon. Now the weather Radar indicates a bit of heavier rain.
Matt.
Please be high enough to be visible when I have everything put together!
#6
Posted 29 November 2020 - 02:14 PM
Last night they where less than 2 degrees apart as of last night. I can get both in the eyepiece in my C80ED with a 34mm SWA, but Saturn is very small.
Who else now seeing both of them together?
- flt158 likes this
#7
Posted 29 November 2020 - 10:16 PM
I viewed both at 18x in my AT80ED with a 32mm tonight. Binocular territory for magnification, but still interesting.
#8
Posted 30 November 2020 - 01:50 PM
Did you make out the rings at 18x? I think you need 50x+ to see them clearly?
#9
Posted 30 November 2020 - 04:44 PM
Saturn looked slightly elongated, just enough to tell that something is different about that planet.
- flt158 likes this
#10
Posted 01 December 2020 - 01:44 PM
I have that 80mm scope, but I think I'll use my 80ED f/600mm to view it. It has a maximum FOV of 4* with my 40mm SWO, so I'll be watching it the 3 days before in case we get clouds on the 21st.
- flt158 likes this
#11
Posted 01 December 2020 - 03:52 PM
For a discussion on the minimum magnification to see that Saturn is ringed go to https://www.cloudyni...sini-division/Â
Saturn was at a maximum of 15.5 degrees when I did those tests from the south of the UK. It'll be even lower on the day of closest approach on the 21st. Some of you in more southerly latitudes will get a much better view than us, so the test results may be more relevant.
- zjc26138 and flt158 like this
#12
Posted 02 December 2020 - 08:04 PM
In the past, using my 70mm Jason ( store brand for sure!) refractor, I viewed a conjunction of Mars & Saturn. I could definitely see a ring around that planet at 60X. One of my best memories of my very early astronomy days back in the 70s.
Clear Skies,
Matt.
- flt158 likes this
#13
Posted 03 December 2020 - 12:03 PM
The two planets easily fit into the 13x, 3.7-degree true field of view produced by a 30mm Celestron Ultima and a bit less so into the 17x, 2.4-degree true field of view produced by an 8-24mm Tele Vue Click Stop Zoom eyepiece set at 24mm and my 80mm f/5 Orion ShortTube 80 refractor last night.
- flt158 likes this
#14
Posted 03 December 2020 - 01:00 PM
I was out last night and Sky Safari says they are now less than 2* apart now. Both easily fit in the finder scope. I tried my 24mm 68* EP in my 4" fract at 40x and they would not fit yet. The rings where barley visible. These articles showing both planets with Saturn's rings and moons are not accurate. The planets where about 24* above the horizon at 6 pm. I thought I may have to drive somewhere to view it on the 21st, but may not.
- flt158 likes this
#15
Posted 03 December 2020 - 01:02 PM
The two planets easily fit into the 13x, 3.7-degree true field of view produced by a 30mm Celestron Ultima and a bit less so into the 17x, 2.4-degree true field of view produced by an 8-24mm Tele Vue Click Stop zoom eyepiece set at 24mm and my 80mm f/5 Orion ShortTube 80 refractor last night.
No rings at 13x, right?
- flt158 likes this
#16
Posted 04 December 2020 - 07:29 PM
Definitely not at 13X, or everyone with binoculars would rave about the ringed planet. No, in my aforementioned Jason refractor it took about 45x to 60X to see the Ring clearly. I never could see beyond that in that scope.. Bothe Aperture & magnification both being too low.
Clear Skies,
Matt.
- flt158 likes this
#18
Posted 05 December 2020 - 10:13 PM
I was able to get them both in a single view tonight in my 102mm f/7 refractor with a 22mm 82 degree eyepiece. This produced a true field of view of 2.5 degrees and 32x magnification.
Both planets just fit in so I estimate the current separation to be just under 2 degrees, maybe around 1.75 or so. Saturn and its rings were clear and sharp as were Jupiter and the 4 Galilean moons.
- Illinois, flt158 and TimothyPleiades like this
#19
Posted 06 December 2020 - 01:25 PM
Yesterday evening I used my Orion 80ED and ES 24mm 82 deg. Eyepiece for 25 power 3.28 degrees. I can see Jupiter, Jupiter’s 4 Moon, Saturn and Saturn’s tiny ring all in one view. Nice view!
Me too with the same scope and EP you have! Tough to make ou the rings at 25x Saw two faint moons of Saturn. Jupiter, no problem, all 4 of them. Also saw a fairly bright meteor in Gemini around 9pm.
- Illinois and flt158 like this
#20
Posted 07 December 2020 - 02:36 AM
Using my 80mm f/5 Orion ShortTube 80 refractor and a 30mm Celestron Ultima eyepiece (13x), I observed Jupiter and Saturn simultaneously on Sunday evening. The two gas giants just fit into the field of view of an 8-24mm Tele Vue Click Stop Zoom eyepiece set at 20mm (20x). I also viewed the two planets separately at the 8mm setting (50x).
Here's an afocal iPhone photo that I took through the refractor and the 30mm Ultima.
- FXM, Illinois, REC and 1 other like this
#22
Posted 09 December 2020 - 01:03 PM
From Dec 6th around 5PM
Image with a Nikon 80-400mm set to about 340mm 1.3 second @f/8
Sky-Watcher Star Adventurer mount.
I am sure on the day of the event, the weather will be cloudy. :-)
Wow, that's the best shot I have seen so far! See you got 3 moons of Jupiter!!
- FXM and flt158 like this
#24
Posted 09 December 2020 - 05:22 PM
Certainly not.
It usually takes around 25x for me to be able to resolve Saturn's rings without question.
- flt158 likes this
