Bright nova in Perseus - N Per 2020
68 replies to this topic
#26 descott12
descott12
  • Loc: Charlotte, NC
Posted 25 December 2020 - 12:35 PM
I went back and following mwr's lead, I have identified a bunch more lines. Does the presence of these N, O and C lines indicate the nova is now in the "nebular" phase?
#27 mwr
mwr
Posted 26 December 2020 - 05:56 AM
Hi Dave,
in the nebular phase the forbidden lines like [O I] 6300, [O III] 5007 and N [II] 5755 become dominant and the Fe II lines fade away. The nebular phase starts when the maximum brightness of the nova has diminished by about 3.5 magnitudes. So the nova is not yet in the nebular phase and I estimate that the forbidden lines will become well visible around values of 12-13 mag - too faint for my setup :-(
Edited by mwr, 26 December 2020 - 05:58 AM.
#28 Bräumer
Bräumer
  • Loc: Germany, Hessen
Posted 26 December 2020 - 08:54 AM
Does anyone have any information about how far the nova is from Earth?
#29 descott12
descott12
Posted 26 December 2020 - 09:20 AM
Hi Dave,
Ah. Thanks for the explanation. Yes Walker explains a bit of this on page 134 but I did not realize the Fe II lines would disappear.  I will definitely keep a watch on this one. I wonder if I can capture it at Mag 12-13? I will certainly give it a try.
Very interesting stuff.
#30 robin_astro
robin_astro
Posted 26 December 2020 - 10:42 AM
Novae vary quite a lot in absolute magnitude  so are not very good "standard candles" but we can make a very rough back of envelope estimate.
If we start with a typical absolute magnitude at maximum of say approximately -8 (from the reference in wikipedia) and then correct for the ~2.5 magnitudes of interstellar extinction estimated from from the strength of the interstellar lines,  E(B-V) ~0.8
http://www.astronome...org/?read=14229
this gives a rough corrected absolute magnitude of  -5.5
From AAVSO data the apparent V magnitude at maximum was ~ 8.3
We can use these absolute and apparent magnitudes to estimate a distance of ~6kpc, though given the uncertainty in absolute magnitude, this could be a few times too large or small
Cheers
Robin
  • flt158 and Bräumer like this
#31 mwr
mwr
Posted 26 December 2020 - 10:48 AM
Hi Kalle,
I haven't found yet a published distance but it can be estimated by using Cohen's formula for galactic novae (ASPC 4 (1988) 114-127; http://adsabs.harvar...ASPC....4..114C):
MV = -10.66 + 2.31*log t2 (in words: the absolute brightness can be calculated by the time (in days) that gives a decay of 2 mag in apparent brightness). t2 can be estimated from AAVSO data (Nova Per 2020 = V1112 Per) to be about 25 days (with mmax = 8.5 mag). This yields an absolute magnitude of MV = -7.43
The inverse square law for light tells us how an object's apparent brightness depends on its luminosity and distance and this allows us to calculate the distance of this nova by using the "photometric parallaxe":
d (parsec) = 10 exp ( (m-MV-AV+5) / 5 ) with AV = sum of circumstellar and interstellar extinction = 0.55 mag
This yields an estimation for the distance of 11912 parsec or 39708 light-years.
#32 mwr
mwr
Posted 26 December 2020 - 11:13 AM
Cheers
Robin
I haven't seen Robin's post that appeared almost simultaneously with my post. Robin's value for the interstellar extinction is certainly a much better estimation. Using 2.5 mag for AV yields a distance of 4.8 kpc or about 16000 light-years.
#33 Bräumer
Bräumer
Posted 26 December 2020 - 04:13 PM
Thank you both for your estimate!
You really help me in this thread to understand the nova :)
Kalle
  • flt158 likes this
#34 robin_astro
robin_astro
Posted 26 December 2020 - 07:59 PM
A brief foray into the IR with the LHIRES III and 600l/mm grating. A red (610nm long pass) filter was used to ensure no contamination from the 2nd order. beta Aur was used as a reference for response correction.
Cheers
Robin
  • mwr likes this
#35 descott12
descott12
Posted 26 December 2020 - 09:33 PM
Cheers
Robin
Pretty cool that I was able to capture the two larger peaks with my SA-100 and there is actually a  hint of the central peak 8200 as well.
#36 mwr
mwr
Posted 26 December 2020 - 10:28 PM
Cheers
Robin
Hi Robin,
a fascinating high resolution profile of the O I line at 8446 Angström !  It would be interesting to see if a suitable scaled velocity profile of this emission line can be somehow fitted to calculated profiles of ellipsoidal shells with equatorial and polar rings at different angles of inclination:
Gill and O'Brian have presented numerous "Emission-line profiles from model nova shells" here: https://academic.oup...07/3/677/961689
#37 mwr
mwr
Posted 27 December 2020 - 04:17 AM
I have just found Robin's spectrum in the BAA database and it seems that the calculated line profile for a simple ellipsoidal shell with an equatorial ring and polar rings of enhanced brightness with an inclination angle of 60° gives the best fit for the O I emission line:
I haven't found out yet how to calculate a velocity profile from an emission line in VSpec but the maximum velocity for the ejecta that form the top ring should be around 900 km/sec.
  • robin_astro likes this
#38 mwr
mwr
Posted 27 December 2020 - 05:49 AM
Actually not that difficult:
Richard Walker has written a very useful Tutorial that shows how to scale the x-axis in Doppler velocity:  https://www.ursusmaj...a_reduction.pdf
#39 robin_astro
robin_astro
Posted 27 December 2020 - 07:51 AM
Tim Lester's PlotSpectra
http://www.spectro-a....php?f=8&t=1596
(latest  version at end of thread)
can display any selected region of the spectrum in velocity space
You can even overlay different lines simultaneously eg as here in Nova Cas 2020
http://www.spectro-a...&p=15078#p15078
Cheers
Robin
Edited by robin_astro, 27 December 2020 - 07:54 AM.
  • RobboK likes this
#40 robin_astro
robin_astro
Posted 28 December 2020 - 05:39 PM
Cranking up the resolution  on the OI 8446 line to R~7000 by moving to the 1200l/mm grating
Robin
  • mwr likes this
#41 descott12
descott12
Posted 28 December 2020 - 05:57 PM
Robin
Beautiful! I am guessing your exposure has to get pretty long to support that resolution?
#42 Bräumer
Bräumer
Posted 29 December 2020 - 08:10 AM
It seems like I have a question again, I hope you can help me out again.
I have looked at the article and wonder, how is it possible to determine the E(B-V) just by looking at the interstellar lines? E(B-V) is a color excess, isn't it?
Wikipedia told me: "Also significant is that the strength of DIBs is broadly correlated with the interstellar extinction."
But why? And how exactly can you determine the color excess?
Kalle
Edited by Bräumer, 29 December 2020 - 08:11 AM.
#43 robin_astro
robin_astro
This was two hours (12x600s) but there was a lot of thin cloud around so I probably lost about half the signal. There seems to be quite a lot going on the in continuum that does not look like random noise. Fringes can be a problem at high resolution in the IR  but the flat seems pretty clear of them.
#44 robin_astro
robin_astro
Posted 29 December 2020 - 02:51 PM
Kalle
E(B-V) is used as a shorthand for extinction but the interstellar medium has various properties which can be used to estimate empirically  how much there is between us and the object.
One is that it absorbs different wavelengths by different amounts, in general  absorbing less at longer wavelengths making objects look redder.  This is normally described as E(B-V), The difference between the expected (B-V) brightness values for a star (based on its spectral classification) compared with the measured B-V.
The actual absorption in the V band is ~3x E(B-V).  In this case we cannot use this however as we do not know what the spectrum should look like so we do not know what the (B-V) should be
The interstellar medium is made up of various substances however, some of which produce specific extra absorption lines in the spectrum of the nova. By measuring the depth of these lines we can estimate the amount of interstellar material. In this case lines produced by sodium and potassium in the interstellar medium were used to estimate the extinction.
Note these lines are different from the diffuse interstellar absorption bands which are thought to be produced by molecules in the interstellar medium. Their distribution of these varies so can only be used to approximately estimate extinction.
Robin
Edited by robin_astro, 29 December 2020 - 02:59 PM.
#45 Bräumer
Bräumer
Posted 29 December 2020 - 05:01 PM
Oooh, ok. So the strength of interstellar absorption lines is directly related to the strength of the extinction?
#46 robin_astro
robin_astro
Posted 29 December 2020 - 06:43 PM
The strength of the interstellar absorption line in the spectrum of the target gives a measure of the amount of that particular  substance between us and the target. There is then an empirical relationship between that and the amount of dust causing the extinction. See here for example where the interstellar sodium D absorption line was used to track the extinction due to dust in the Milky Way
https://academic.oup...6/2/1465/975270
Cheers
Robin
#47 Bräumer
Bräumer
Posted 30 December 2020 - 03:30 AM
Thank you Robin, I appreciate your explanation!
#48 robin_astro
robin_astro
Posted 30 December 2020 - 11:08 AM
A lower noise version from last night. Lots of structure in the  line profile
Robin
  • RobboK and mwr like this
#49 descott12
descott12
Posted 30 December 2020 - 11:54 AM
Robin
Hey Robin, to get lower noise was that a longer exposure to boost SNR or was the previous curve simple smoothed a bit?
#50 mwr
mwr
Posted 30 December 2020 - 02:37 PM
Hi Robin,
great spectrum! I have applied the low-pass filter function in VSpec to your spectrum and it looks like a six-peaked structure in a
classical-nova-shell line profile in the form of an inclined ellipsoidal shell with enhancements in equatorial and tropical rings. The similarity to the peak structures of the forbidden lines of the nova V705 Cas (inset) is really striking:
The peaks in the profile are clearly brighter in the red than the blue but otherwise placed symmetrically about their rest wavelength.
Thanks for sharing your spectra.
