My Orion StarBlast and SkyScanner are both f/4 scopes. From what I’m learning, very fast scopes do better with eyepieces that can handle that range. Any recommendations on what these eyepieces would be? I’ll probably keep it in the 20mm - 32mm range.
Eyepiece recommendations for f/4 scope?
#1
Posted 29 November 2020 - 01:02 AM
#2
Posted 29 November 2020 - 01:16 AM
- BDS316, havasman and Atlantic Devil like this
#3
Posted 29 November 2020 - 01:44 AM
The Orion Sirius eyepieces are good values and good quality. They should work fine with your scopes. Their field of view is fairly narrow at 52mm. To go wider and have good quality with an f/4 could mean eyepieces that cost more than your telescopes.
You mentioned a range of 20mm to 32mm.... the exit pupil (width of the beam of light coming out of the eyepiece and into your eye) is getting pretty wide in the upper part of this range. At some point, the blockage in the light path caused by your secondary mirror will become large enough to be visible as a dark smudge in the middle of your field of view. A good rule of thumb is to not go wider than 7 times your focal ratio, or 28mm in your case. Personally, I probably would not exceed 25mm.
Edited by StarryHill, 29 November 2020 - 01:47 AM.
- BDS316 and Atlantic Devil like this
#4
Posted 29 November 2020 - 02:05 AM
Scott
- Jon Isaacs, StarryHill, 25585 and 2 others like this
#5
Posted 29 November 2020 - 05:03 AM
Best performance at f4 - Ethos, Naglers, Morpheus, ES92, ES82, ES100, APM HDC, APM UFF, etc. All used with Paracorr/Paracorr 2.
Yes, buy for the 8" if you have it. Consider putting your scopes in your signature line by clicking on your name in top right corner of the page, my profile, edit profile, signature.
- Sarkikos and Atlantic Devil like this
#6
Posted 29 November 2020 - 11:32 AM
https://www.teleskop...connection.html
this serie look like a rebadged vixen LVW.
Edited by jjack's, 29 November 2020 - 11:39 AM.
- Atlantic Devil likes this
#7
Posted 29 November 2020 - 11:39 AM
He listed both his scopes. These eyepieces are all more expensive than either of his scopes and a paracorr won’t work in a 1.25” focuser. Recommending eyepieces for a 20” F4 Starmaster is different than recommending eyepieces for a Starblast or Skyscanner.Best performance at f4 - Ethos, Naglers, Morpheus, ES92, ES82, ES100, APM HDC, APM UFF, etc. All used with Paracorr/Paracorr 2.
Scott
Edited by SeattleScott, 29 November 2020 - 11:39 AM.
- ShaulaB, PatrickVt, j.gardavsky and 2 others like this
#8
Posted 29 November 2020 - 12:11 PM
- Starman1, vdog, Atlantic Devil and 1 other like this
#9
Those are the ubiquitous Barsta 70° series that first appeared as the Celestron Ultima LX, then the Astrotech AF70, then innumerable brand names like Olivon 70, Astromania SW, et.al.
Made in China (LVWs were made in Japan), and not duplicates of the LVW, though obviously modified copies of them, given similar focal lengths.
I go along with the suggestion that simple Plössls are the most cost-effective eyepieces here, given the OP's scopes.
Or maybe the 58-60° eyepieces available for $60-$80 each if the OP feels like splurging. Expensive eyepieces make no sense in recommendations.
- SNH, Atlantic Devil and isolli like this
#10
Posted 29 November 2020 - 12:37 PM
I used to have a Starblast. The recommended Celestron Zoom was actually my main eyepiece for that scope. I enjoyed a lot of targets with that combo. It won't give you a wide angle view, though, if that's what you're looking for, as it's about 40 degrees at the high end.
If I were looking for a max focal length, wide-FOV eyepiece for that scope now, I'd probably get that 70 degree 22mm recommended above.
#11
Posted 29 November 2020 - 11:51 PM
I currently have that kit from celestron that comes with 8, 6, 13, 17, and 32mm eyepieces, a 2x Barlow and some color filters. I'm going to order some of the celestron x-cel LX eye pieces. The thing is I don't know which of my current eye pieces should really be replaced. I also have 10, 20, and 25 Orion Sirius plossl eye pieces.
#12
Posted 30 November 2020 - 12:51 AM
The priority would be replacing the 32mm Plossl with the 25 Xcel LX in Oder to get a more reasonable exit pupil at F4. After that I would look at what plossls have uncomfortable eye relief for you, maybe 10mm and shorter FL, and upgrade to the Xcel 9 or 7 or something.I currently have that kit from celestron that comes with 8, 6, 13, 17, and 32mm eyepieces, a 2x Barlow and some color filters. I'm going to order some of the celestron x-cel LX eye pieces. The thing is I don't know which of my current eye pieces should really be replaced. I also have 10, 20, and 25 Orion Sirius plossl eye pieces.
Scott
#13
Posted 30 November 2020 - 05:08 AM
Good information as usual Don. Thanks.
They say they are good to f/4. They are surely wrong ! The eyepieces you quote are not.
#14
Posted 30 November 2020 - 09:59 AM
True, but eyepieces that ARE good to f/4 will be more expensive than can be justified for the economical scopes in question.
Even TeleVue Delites, which are good to f/4 and would be great candidates, are too expensive to be justified for these scopes.
I blame the manufacturers of scopes that they would even make entry level newtonian scopes below f/6 because the coma will be severe even if the eyepiece is well corrected at f/4,
and the eyepieces used with these scopes likely won't be.
Plössls would be a good compromise and quite affordable.
- jjack's, Thomas_M44, Atlantic Devil and 1 other like this
#15
Posted 30 November 2020 - 02:24 PM
Exactly.
It's just this kind of lower price-point, fast f-ratio scope scenario in which better-quality Plossl's can be an attractive option.
A set of eyepieces costing $200 apiece or more for use in a $200 to $400 telescope --that's difficult value proposition.
#16
Posted 30 November 2020 - 03:53 PM
Scott
I read that the 32mm that comes with that kit is actually pretty good. But since i have nothing to compare it to, i cant tell for sure.
#17
Posted 30 November 2020 - 03:55 PM
Well, i just ordered an Agena Starguider Dual ED 12mm. Supposedly, they are really good. Guess I'll find out soon.
- Thomas_M44 likes this
#18
Posted 30 November 2020 - 04:14 PM
The 32mm that comes with it is probably a fine eyepiece. But a 32mm Brandon wouldn’t be a good match for a F4 scope. It isn’t an issue of the eyepiece quality. It is an issue of the eyepiece focal length relative to your scope’s F ratio.I read that the 32mm that comes with that kit is actually pretty good. But since i have nothing to compare it to, i cant tell for sure.
But the 12mm paradigm should be a nice improvement and an introduction to 60 AFOV eyepieces. It just wouldn’t have been my first choice personally. Not saying you could do much better without spending much more money. I just would have prioritized low power or replacing a higher power Plossl with uncomfortable eye relief.
Scott
#19
Posted 30 November 2020 - 04:30 PM
Scott
The new lens is mainly going to be for my StarNavigator. That one is an f/13.8 and a 12mm is probably the highest magnification I'll use on it as going over 105x probably won't do me any favors.
#20
Posted 30 November 2020 - 04:37 PM
#21
Posted 01 December 2020 - 12:30 AM
I'm wondering if a 4mm Agenda Starguider Dual ED will be too high for my F\4 scopes...
#22
Posted 01 December 2020 - 02:10 AM
#23
Posted 01 December 2020 - 11:19 AM
I thought there were 4mm Starguider eyepieces. Looks like there isn’t. I’ll probably just go with a 5mm Starguider or X-Cel LX.
#24
Posted 01 December 2020 - 12:15 PM
Note the Xcel LX 5mm is really 4.5mm. I recently read a rather poor review of this eyepiece so the 5mm paradigm might be a safer bet.
Scott
#25
Posted 01 December 2020 - 01:24 PM
In my Starblast, I used a 3mm eyepiece for 150x magnification. Collimation had to be spot on, but I was able to observe the Cassini division, Titan, the Great Red Spot, and subtle hints of the maria on Mars with that combo.
It was pretty much just for the moon and planets, though. Everything else was pretty dim at that magnification.
Edited by vdog, 01 December 2020 - 01:24 PM.
