Mirror test
29 replies to this topic
#1 Jeff L
Jeff L
  • Loc: Easton. Pa
Posted 29 November 2020 - 01:05 PM
Is there a test I can perform on my new xx14g mirror to see if I got a good one or do I have to send it to someone?
#2 BradFran
BradFran
  • Loc: Villingen-Schwenningen, Germany
Posted 29 November 2020 - 01:13 PM
Star test and Ronchi test. An inside and outside of focus star at around 1mm exit pupil (eyepiece focal length equal to your f/ratio) will show how good your mirror is. It depends on having good collimation, thermal equilibrium and steady atmospheric seeing though. A Ronchi test is similar, but holding a screen in front of your focuser and analyzing the lines on the grating. Search around here for more info.
  • Jeff L likes this
#3 junomike
junomike
  • Loc: Ontario
Posted 29 November 2020 - 05:45 PM
Look at the Planets and/or Globulars at 300X - 400X.  If the Image is sharp and offers a "wow", ya got a good one.
  • icomet, Jeff L and Woj2007 like this
#4 Jeff L
Jeff L
  • Loc: Easton. Pa
Posted 29 November 2020 - 05:52 PM
And if not what do I do?
#5 kfrederick
kfrederick
Posted 29 November 2020 - 06:21 PM
I live in Bedford Pa stop by I test it
  • Jeff L likes this
#6 junomike
junomike
  • Loc: Ontario
Posted 29 November 2020 - 08:42 PM
See what max magnification you can obtain.
#7 junomike
junomike
  • Loc: Ontario
Posted 29 November 2020 - 08:43 PM
This sounds like a good solution
  • BDS316 likes this
#8 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 30 November 2020 - 08:37 AM
Yep, and a similar test is the snap to focus test. Poor scopes (or conditions) will tend to mush through focus. A good scope (under good conditions) will have a more convincing focus. Focus will not be in doubt as it tends to "snap" into focus instead of mushing through focus. Good scopes will take higher magnification while with poor scopes the degradation becomes visible at around 1x per millimeter of aperture, give or take.
You can do a simple star test by scrolling through focus a little on both sides (3 or 4mm) when the scope is well collimated and at thermal equilibrium. If the defocused image looks pretty much the same on both sides at about the same defocus, your scope is probably okay. It probably won't look exactly the same on either side, but similar enough is good enough.
Edited by Asbytec, 30 November 2020 - 08:37 AM.
  • Jeff L likes this
#9 Bean614
Bean614
  • Loc: Mass.
Posted 30 November 2020 - 09:23 PM
All of these well meaning suggestions,  of course, Assume you know how to properly Collimate your scope!  If it's not properly collimated,  then ANY of those tests are completely meaningless.
  • Bob4BVM and Jeff L like this
#10 GUS.K
GUS.K
  • Loc: Katoomba, NSW, Australia.
Posted 30 November 2020 - 11:18 PM
Don't worry about testing yet, if you don't already know, learn how to collimate it and just enjoy the views.
  • kfrederick, Bob4BVM and Jeff L like this
#11 RobertMaples
RobertMaples
  • Loc: Murfreesboro, TN
Posted 01 December 2020 - 08:00 AM
That's not a good test unless you know the seeing is very good.  You could have an almost perfect mirror and have the image break down well below 300x with bad seeing.
  • happylimpet and Bob4BVM like this
#12 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 01 December 2020 - 08:31 AM
Yes, that's true. But, if the image is clean and sharp, then seeing and the scope are good. If the image breaks down below 300x, then it's probably seeing. If so, any image wavering should be an indication of poor seeing and should make testing for quality more difficult. I understand this is your point well taken.
#13 Jeff L
Jeff L
  • Loc: Easton. Pa
Posted 01 December 2020 - 08:09 PM
I use the hotech lazer collimater. It’s quite simple to collimate with it.
#14 Jeff L
Jeff L
  • Loc: Easton. Pa
Posted 01 December 2020 - 08:27 PM
This is my second xx14g. The first one I bought used it was about eight years old. I sold it then bought another brand new one. This one doesn’t seem to “snap” to focus. Ive only had it out twice both times the seeing wasnt excellent by any means. The stars were dancing anyway. I forgot about the star test focus deal. I’ll try that next time. Hopefully the moon won’t be in the way either.
#15 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 01 December 2020 - 09:13 PM
Even if the image doesn't snap to focus during lesser seeing, the star test being more similar than dissimilar on both sides of focus will be telling. You may be able to read through some level of lesser seeing. Be sure the primary is thermally stable, the star test is that sensitive.
  • SteveG and Jeff L like this
#16 Jeff L
Jeff L
  • Loc: Easton. Pa
Posted 04 December 2020 - 06:06 AM
https://optcorp.com/...iece-10-101-150
Anybody try one of these ?
#17 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 04 December 2020 - 06:14 AM
No, but now I have to get one, too. Thanks.
I've used 133 LPI Ronchi gratings, just slap it over the focuser.
Remember, this is a null test. Straight is good.
  • sopticals and stargazer193857 like this
#18 esd726
esd726
  • Loc: Rochester, IN
Posted 04 December 2020 - 06:43 AM
Edited by esd726, 04 December 2020 - 06:43 AM.
#19 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 04 December 2020 - 06:40 PM
I got one years ago to test optics.  A great tool.  You can evaluate the optics in a scope quite easily with one, and see zones and bumps in the mirror surface, and evaluate correction at the focal plane.
One thing to remember is that you are evaluating both mirrors together.
  • tboss70, stargazer193857, Bob4BVM and 1 other like this
#20 Spikey131
Spikey131
Posted 04 December 2020 - 07:18 PM
A 14” scope in Easton, PA is not going to “snap” into focus very often.....grin.gif
  • tboss70 and BDS316 like this
#21 Pinbout
Pinbout
Posted 04 December 2020 - 10:36 PM
a good mirror looks like this with 2 lines
https://youtu.be/z3xQhmI81kw
if it wasn't good you'd see the lines go like )( to () or the other way depending on the direction of the correction error.
with the ronchi you have to go 2 line inside of focus to 2 lines outside of focus... keep flipping to help see if the lines do )( to ()
also you could have a secondary that isn't flat enough... that will look like astig in a star test very close to focus...
the every so slightly defocused star will look like - then |  going from inside to outside of focus
  • stargazer193857 likes this
#22 Starman1
Starman1
  • Loc: Los Angeles
Posted 05 December 2020 - 11:34 AM
You might like to see what can be seen with a Ronchi grating mounted in an eyepiece:
https://www.teleskop...nchi-manual.pdf
  • SteveG and stargazer193857 like this
#23 Jeff L
Jeff L
  • Loc: Easton. Pa
Posted 05 December 2020 - 07:55 PM
I ordered the one in my post, #16
#24 tboss70
tboss70
  • Loc: Missouri
Posted 05 December 2020 - 08:10 PM
I ordered one about a 4-6 weeks ago....still waiting.
  • BDS316 likes this
#25 Jeff L
Jeff L
  • Loc: Easton. Pa
Posted 24 December 2020 - 05:32 PM
Did you get yours yet? I ordered one on Dec 4 still waiting
