.Can anyone help me identify this Meade product? Its a focal reducer that attaches directly to the diagonal. Mainly I'm trying to figure out the percentage of reduction. Cant seem to find any Meade focal reducers that look like it though.
Posted 29 November 2020 - 06:53 PM
That's the Wide Field Adapter and Telecompressor system (1 part diagonal, 1 part compressor, 1 part T-adapter).
Celestron had a similar model dubbed the Rich Field Adapter.
The reducer/compressor was a basic ~30mm achromat which yielded an effective ~ f/5 when attached to either 8-inch SCT (so, ~.5x, of course). No field flattening or other correction(s), and both were designed for 1.25-inch outputs.
The moving-primary focal systems allowed for visual use with both the WFA and RFA, but the results were not (ahem - pardon the play on words) "stellar." Two-inch adapters and diagonals available at the time yielded much better results at the eyepiece (albeit, at the native f/10). The market lifespan of both systems was effectively squelched by the .63x reducer/correctors later introduced by both companies.
Best wishes.
Dan
Edited by MisterDan, 29 November 2020 - 06:55 PM.
Posted 29 November 2020 - 08:15 PM
Thanks MisterDan =)
Posted 01 December 2020 - 02:20 PM
You can easily gauge the reduction exactly for a specific eyepiece in your scope:
1.Time the passage of a star near the celestial equator (where stars move faster) across the field with the standard diagonal, no reducer.
2.Time the passage of a star in the same eyepiece with the reducing system.
1÷2 = % of the reducer. So 100 - that % = reduction percentage.
Example:
2 minutes 12 seconds = 2.2 minutes
4 minutes
2.2 / 4 = 0.55 = 55% It would be described as a 0.55 reducer.
100% - 55% = 45% reduction.
Equipment Discussions →
Refractors →
Looking for a Good 60mm Guide-ScopeStarted by Jim Waters , Yesterday, 11:17 PM ![]() |
Astrophotography and Sketching →
Beginning Deep Sky Imaging →
Polar-Aligning Skyguider ProStarted by mgermani , Yesterday, 07:49 PM ![]() |
Eyepieces →
Best eyepiece for viewing planets on a 10" Meade LX2000 ClassicStarted by kenbayne , Yesterday, 06:59 PM ![]() |
Equipment →
Is ZWO becoming the Apple of the Astro World?Started by Seaquel47 , Yesterday, 06:20 PM ![]() |
Mounts →
Skywatcher EQ Mounts and Synscan HandsetsStarted by Stevie B , Yesterday, 06:08 PM ![]() |
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
