Monochrome camera choice
4 replies to this topic
#1 senzala
senzala
Posted 01 December 2020 - 12:38 AM
Hi all
I'm looking for a decent monochrome camera for guiding and solar/lunar imaging.
Would Zwo asi 120mm be sufficient or do I need more resolution?
#2 moonrider
moonrider
  • Loc: Murphy, NC
Posted 01 December 2020 - 01:08 AM
I use the ZWO for guiding and it works great. Never used it for anything else. I would think it would do ok for lunar but not for solar...
#3 bobzeq25
bobzeq25
Posted 01 December 2020 - 01:22 AM
Hi all
Resolution is not really the issue.
The chip on the 120 is tiny, so the FOV on solar or lunar will be small.  But, it's extremely economical, about $150.  It will guide fine with a guidescope, not so well with an off axis guider.
The 174 has a much bigger chip.  Better FOV.  Better sensitivity.  Excellent solar/lunar camera, although the large pixels may mean you'll want a Barlow.   Guides well on anything, the big chip may be underutilized on some off axis guiders, because their prism is not big enough to cover it.  Not a performance issue, though.  About $500.
I have both.  Started with a 120, now use the 174.
Those bookend your choices.  The 290 and 178 are in between pricewise, but still have a small chip.  More sensitivity than a 120, so better for off axis guiders.
For an OAG, you'll want the mini versions.  Those come in 120, 290, and 174.
Bottom line.  With a small budget, and no intention to use an OAG, the 120 will work, although you'll only capture a small part of the Moon and Sun.  If budget permits, the 174 is an excellent choice.
Note that you asked the question on a DSO imaging site.  You'll get more and better answers about lunar/solar on the relevant forums.
Edited by bobzeq25, 01 December 2020 - 01:50 AM.
  • Stelios likes this
#4 senzala
senzala
Posted 01 December 2020 - 09:18 AM
I have barlow and focal reducers so it will not be a problem to get close to the sun.
I use a evostar 120mm refractor.
I just wondering if I can get nice pictures of sunspots and penumbra with camares like 120, 290, 174?
I already own a 290mc - colour version, but as I understand monochrome cameras are optimal for solar imaging as well as guiding.
Thank you
Edited by senzala, 01 December 2020 - 09:22 AM.
#5 bobzeq25
bobzeq25
Posted 01 December 2020 - 01:05 PM
Thank you
Ask on the solar forum.  But, I started a thread there on a potential purchase of a solar scope.  There was some info about cameras.  People seemed to like the 174.
If the cost isn't too much, I think the 174 is your clear "best" choice for everything you want to do.  Mine guides well, and I use it on both a guidescope and an OAG.  Here's a lunar image of mine, with my 130mm F7 and 2.5X Barlow.  Click on it to zoom in some.
https://www.astrobin.com/328429/0/
Here's someone else's Sun with a simple cheap white light filter.
https://www.astrobin.com/298434/
And one with a very expensive ($1500?) Quark H alpha filter.  No doubt an experienced solar imager, also.
https://www.astrobin.com/esv3f4/0/
The point of the last image is mostly to show you that some very serious people use a 174 on the Sun.
Edited by bobzeq25, 01 December 2020 - 01:36 PM.
