Odd Grid Pattern in light? Help?
11 replies to this topic
#1 robonrome
robonrome
  • Loc: Brisbane, Australia
Posted 01 December 2020 - 02:59 PM
just starting imaging last night and this really odd grid pattern appeared across the lower right. It gradually faded over a few lights, but concerned what it is an how to stop it.
I noticed it once before when taking test flats but thought it was a pattern from my Light Panel, but obviously not when showing up in a Sub frame here so must related to camera or image train. Nothing on lens or filter or on sensor glass I can see, so presumably something deeper. Camera ASI071MC pro. I'm in a fairly warm humid environ (25deg C last night). Dew Heater is on and camera cooled to -5deg C.
Any help to resolve appreciated.
#2 Topographic
Topographic
  • Loc: Tarn et Garonne, France
Posted 01 December 2020 - 03:28 PM
condensation on the chip.
  • John O'Grady and robonrome like this
#3 pyrasanth
pyrasanth
Posted 01 December 2020 - 03:30 PM
Agreed- check that your heater is turned on in the camera settings. If not- it's broken and the camera needs servicing.
#4 John O'Grady
John O'Grady
  • Loc: Waterloo, ON CAN
Posted 01 December 2020 - 03:32 PM
Agreed, as strange as the pattern is, if it faded over time.  Particularly if cleared from the center outward to the corner, that's a clear sign you had condensation on the chip.
How long a duration do you allow the sensor to cool for?
  • robonrome likes this
#5 ram812
ram812
  • Loc: Grants Pass, Oregon
Posted 01 December 2020 - 03:34 PM
Gotta be dew somewhere in the imaging train, like Topographic says, right on the chip. For a moment I was thinking t-shirt pattern but you used a light panel for your flats (How do they look?). Real humidity and a very cool camera will cause dew to form on a chip, though. Ralphgrin.gif
#6 Topographic
Topographic
Posted 01 December 2020 - 04:23 PM
Dry out your tabs, and do it regularly. Don't leave your ASI071 outside or in an observatory. It's a really good camera but it is a bit high maintenance. No need to go below -5C (which was your temp) when imaging.
#7 robonrome
robonrome
Posted 01 December 2020 - 05:25 PM
thanks all, makes sense. It is rather humid here in Brisbane Au which wouldn't help. I do have the dew heater switched to on in settings, but maybe it's struggling to keep up... I do hope not broke. I'd have to send this back to the US for fixing.
Would slowing the cooling rate help do you think?
I do bring the scope and camera in each night. Don't leave it out, juts the mount.
#8 Topographic
Topographic
Posted 02 December 2020 - 07:45 AM
Yes, use slow cooling. I use APT rather than leaving it to ASCOM. I tend to dry the tabs after every 4 imaging sessions, or if I haven't used the camera for a while. I also keep a stock of tabs. Try putting the tabs back in warm...seems to help.
#9 robonrome
robonrome
Posted 02 December 2020 - 04:25 PM
Thanks. I've shifted from APT to NINA and I noticed NINA does the cooling and warming quicker than APT... will have to see if NINA can be slowed.
I haven't tried opening the camera yet to get at the tabs near the sensor. Right now I'm trying drying things with the camera in a plastic bag with a bunch of silica gel packets with the side port opened, but expect I'll have to open it up to really address the problem.
I assume it's fairly straightforward removal of the black tiltable top plate? Then take the tabs and zap them in microwave for a few minutes and pit back (warm). ? thanks again.
#10 Topographic
Topographic
Posted 02 December 2020 - 05:08 PM
Side port open? Is yours a 071 cool? I am sure I read somewhere that the side shouldn't be opened on the Pro.
Opening etc is easy just be as dust free as possible. Be aware that old tabs can crumble...not good.
#11 robonrome
robonrome
Posted 03 December 2020 - 05:30 AM
no its a pro. it has a screw-in port on the side though under a rubber plug. I read it was for back up desiccant, but requires tube the pro doesnt include?
#12 Topographic
Topographic
Posted 03 December 2020 - 04:55 PM
Can't remember where I read that you shouldn't open that port, but it is a throwback to the discontinued cool version which I believe came with the tube attachment. The tube is not available as an accessory.
https://www.manualsl...ol.html?page=12
Does the port look like a hole into the chamber, I wonder if that could cause dew issues. Can you shine a light into it to check?
