Does it matter if your Bahtinov mask fits poorly and is off center?
8 replies to this topic
#1 Borodog
Borodog
Posted 01 December 2020 - 07:32 PM
I ordered a Bahtinov mask for my C8. I specifically ordered one that was for older C8s. The one I was sent is marked that it is for a scope with "Hyperstar" (whatever that is) and it does not fit well at all. The center cutout for the secondary mirror is at least half an inch too large and hence the mask hangs off center and substantial light is let in around the secondary. Will this affect the functioning of the mask, i.e. the position of the central line that shifts with focus?
#2 petert913
petert913
  • Loc: Silverton, OR
Posted 01 December 2020 - 07:47 PM
I've often wondered that , too.  I have certainly had my mask off-center and the spikes show up just fine.  So...... ?
  • Borodog likes this
#3 Borodog
Borodog
Posted 01 December 2020 - 08:11 PM
Yeah, I see the spikes. I'm just wondering if the off center mask will *also* shift the central line, which would defeat the purpose.
#4 Sacred Heart
Sacred Heart
Posted 01 December 2020 - 10:43 PM
I would think so longs as you have the pattern on screen, see the cross and straight line, you should be good to go. There is a guy on youtube that made his mask and a few lines broke. They were missing, a bigger gap, did not matter much.
    I'm thinking if you are off center, it will still work, your X or straight line may be shorter.  An off axis solar filter does not show the Sun in one corner or another - it is in the center.  Your pattern may not be in the center but should still focus.
               Joe
#5 dcaponeii
dcaponeii
Posted 03 December 2020 - 06:23 PM
I would err on the side of needing it centered. You can add “fingers” to hold it in position or a spacer that fits around the secondary mount. Since the mask works by generating a symmetrical diffraction pattern when in focus, the symmetry may be affected by having the mask off center.
#6 kathyastro
kathyastro
  • Loc: Nova Scotia
Posted 03 December 2020 - 06:49 PM
The diffraction pattern depends on the angles between the three segments of lines.  Those angles won't change if it is off-centre.
However, the light leakage around the secondary will create another diffraction pattern to each star.  Probably not enough to worry about.  Your best bet is to make a new centre for the mask that fits better and tape it to the mask.
#7 Borodog
Borodog
Posted 03 December 2020 - 07:10 PM
Exactly what I’ve done (except glued).
Edited by Borodog, 04 December 2020 - 06:41 AM.
  • kathyastro and dcaponeii like this
#8 Zippysky13752
Zippysky13752
  • Loc: Florida @ 30 Degrees Latitude
Posted 03 December 2020 - 09:13 PM
I have a long dew shield and have held the mask up to focus stars to avoid bumping the setup.  I have never had a problem with the mask not being perfectly on-center or having gap around the secondary
My opinion - think you will be ok.
#9 Kokatha man
Kokatha man
Posted 04 December 2020 - 01:01 AM
My opinion - ditch that mask...I'm unaware of any hi-res imagers who use such devices to focus any planet..! ;)
  • John Boudreau, KiwiRay and dcaponeii like this
