I have a SkyShed POD so my setup is permanent and when not in use is also covered with a reflective tarp (just in case.)
I just got a ZWO ASI2600MC Pro (to replace my Canon EOS 7D Mark II).
Can you (i.e. is it best practice to) leave the ASI2600MC-P attached to the rear of the OTA all the time?
With my 7D Mark II, I would disconnect it from the T-ring and take it in each night after use. But that was because it could be used during the daytime for other non-astro pictures.
But since the ASI2600MC-P will strictly be used with the telescope, is it okay to leave it attached all the time?
Thank you all for your input,
Lamar
