I was having a lot of trouble with Dew so i wrapped a single electric blanket around my Celestron 9.25 tube and made a leather cover for it to keep the heat in ... I've tested over two nights and it seems to work.
Dew Control
#1
Posted 03 December 2020 - 11:59 AM
- Jim Waters likes this
#2
Posted 03 December 2020 - 12:25 PM
Are tube currents a problem? Some places have two layers. Won't this heat unevenly?
I guess with a low enough setting it might not bother anything.
#3
Posted 05 December 2020 - 09:17 AM
Will this be way too warm? you only need to get just above ambient?
- Biglol likes this
#4
Posted 05 December 2020 - 12:20 PM
Just seems like overkill. Hey! Give it a try. If it doesn't mess with your images, good deal!
There are ways of imaging tube currents. I believe it's the same way you check collimation with a star out of focus. Somebody may be able to be more specific about this method of checking tube currents.
#5
Posted 14 December 2020 - 12:45 PM
Hi People ... Ive used the new Dew shield 4 times now and great success so far ... i will keep monitoring it and let you know how its going.
- mlord likes this
#6
Posted 16 December 2020 - 03:25 PM
Interesting. I recently started to use a double layer of Reflectix around my C8 to slow down cooling, in combination with a dew heater. What is the power output of the electric blanket?
#7
Posted 17 December 2020 - 11:58 AM
I believe its around 15 and 115 watts Depending on what setting you have it on ....On a plus side I've had a lot of success ... im super happy.
- alphatripleplus likes this
#8
Posted 17 December 2020 - 02:48 PM
15W -115W sounds like you have a lot of control on the output, which is a good thing.
- Biglol likes this
