Flat fielding on a WO RedCat 51
10 replies to this topic
#1 enns
enns
Posted 03 December 2020 - 12:20 PM
Hi folks,
I recently dusted off my RedCat 51 (purchased from the kickstarter campaign but not used until covid days). I am having a major challenge getting my flats to remove the heavy vignetting with a FF camera. I am sure this is user error and a rookie mistake but I'm a bit stumped.
To check my work I used pixel math to divide a single light frame by a flat frame ( $T/flat * avg(flat) ) and the result is not good. Similarly when I stack and integrate the entire sequence I end up with a nasty looking vignetted master light frame.
The details are:
scope: WO RedCat 51
camera: Canon EOS R modified
Flats were taken immediately following light frames, using a light panel.
Thanks in advance for your insight!
#2 sharkmelley
sharkmelley
  • Loc: UK
Posted 03 December 2020 - 12:32 PM
Where's your bias?
Try ( ($T-bias)/(flat-bias) * avg(flat-bias) )
Mark
Edited by sharkmelley, 03 December 2020 - 12:32 PM.
#3 enns
enns
Posted 03 December 2020 - 08:14 PM
Thanks Mark, I did that with the bias also, with a similar result that shows heaving vignetting.
Rob
#4 jonnybravo0311
jonnybravo0311
  • Loc: NJ, US
Posted 03 December 2020 - 09:52 PM
Where's your bias?
Mark
Forgive me for the quick hijack, but I'm trying to learn/understand pixel math and your expression doesn't work when I enter it in PI's pixel math process. Specifically, it balks at the "avg(flat-bias)" part of the expression. I was able to get around this by first creating a separate "flat-bias" image and then using that in the expression you shared. In other words, I did this:
  1. Open a flat frame and a bias frame
  2. In pixel math, put in the expression: $T-bias
  3. Have it create a new image as output
  4. Drag the process triangle onto the flat frame
  5. Open a light frame and close the flat frame so that I now have a light frame, a bias frame and the result of my expression in step 2 (I renamed it to flatMinusBias)
  6. In pixel math, enter a new expression: (($T-bias)/flatMinusBias * avg(flatMinusBias))
  7. Drag process triangle onto the light frame
  8. Resulting new image frame should be what your original expression tried to obtain
Did I get that right?
#5 enns
enns
Posted 03 December 2020 - 10:52 PM
Yes... I found the same issue with the expression not working as written, and a similar workaround, to precompute (flat - bias).
  • jonnybravo0311 likes this
#6 jonnybravo0311
jonnybravo0311
  • Loc: NJ, US
Posted 03 December 2020 - 11:11 PM
Thanks for the confirmation :)
#7 sharkmelley
sharkmelley
  • Loc: UK
Posted 04 December 2020 - 06:58 AM
Interesting.  I use a FF camera with the RedCat without problems but for some reason your flat isn't matching the light.  Try a dawn/dusk sky flat instead to see if that helps.
By the way, sorry for the mistake in the Pixelmath formula:  avg(flat-bias).  I had forgotten that avg works only for single images and not for expressions.
Mark
#8 enns
enns
Posted 04 December 2020 - 08:52 PM
Good news, yet confusing news. Through some trial and error, using the ImageCalibration process and then verifying with PixelMath, the following works:
(($T - bias) / flat) * avg(flat)
But if:
1. both the flats and lights are calibrated with bias
or
2. neither the flats nor lights are calibrated with bias
then the flat division results in a badly corrected frame.
The result I verified in PixelMath with RAW CR3 files for the light, flat, and bias frames.
I am confused about this result as it seems that either both, or neither the flat and light should be bias subtracted.
#9 sharkmelley
sharkmelley
  • Loc: UK
Posted 05 December 2020 - 03:01 AM
Lights and flats should both be calibrated by the bias - it's a simple mathematical result.  If you fail to use the bias then dividing the light by the flat will usually under-correct or over-correct depending on the signal levels in each.
Mark
#10 enns
enns
Posted 05 December 2020 - 09:14 AM
Yes, thanks Mark. I think the root cause issue might be (just realized this):
Lights, Darks, Bias: ISO 800
Flats: ISO 100
Calibrating the flats with bias at a much higher ISO looks problematic. So will gather some new data at identical ISOs.
#11 sharkmelley
sharkmelley
  • Loc: UK
Posted 05 December 2020 - 09:30 AM
Yes, I think the EOS R is one of the cameras that has a different bias level at low ISO.
Mark
