Anyone familiar with the NINA sky atlas?
I have no problem to search for the nebulae but I'm not able to search Mars, Jupiter, etc. Any ideas?
Thanks.
Posted 05 December 2020 - 12:24 AM
Thanks.
Posted 05 December 2020 - 01:28 PM
The NINA atlas only includes DSO. No stars or planets.
Posted 06 December 2020 - 10:11 AM
Thanks both! So what if I really want to slew to a planet or star, any solution out there?
Posted 06 December 2020 - 10:25 AM
Connect Stellarium -- https://nighttime-im...ns/planetarium/
Then use Framing Assistant - (See step 2)
Posted 07 December 2020 - 10:39 AM
Thanks, will give it a try!
Any idea how the coordinates from NINA can be sync to Stellarium?
Posted 07 December 2020 - 11:38 AM
There is a button on the Framing Assistant tab to the right of Coordinates that is that.
from https://nighttime-im...e/tabs/framing/
2. Planetarium Sync
Pressing the Planetarium Sync button fetches the coordinates of a selected object from the configured external planetarium program. If no objects are selected in the planetarium the center of frame coordinates are selected as a fallback.
Posted 08 December 2020 - 11:38 AM
2. Planetarium Sync
Thanks! But since I will need to perform a 3 star alignment using my mount hand controller (iOptron CEM40) before each imaging session, how can I ensure the coordination system of the planetarium program (Stellarium) uses the more accurate mount's coordination system (I suppose it should be more accurate after the 3 star alignment) before I use the Planetarium Sync button?
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
