This one took over a month to complete: clouds, full moon, wind, and so on. In total over 8 hours data of which I only could use 4:40 hours.
And also a challenge because my Zwo ASI294MC Pro is back at the store for a check, so I used my Zwo ASI385MC planet camera. Hence the "big" stars.
This is Abell 79 (PN A66 79, PN G102.9-02.3, PK 102-2.1). This object is not very known and as such not much captured. So of course I had to dot it
I gathered info from several online resources.
They are not sure if it is a planetary nebula or a supernova remnant. This also because the center star is a cool dwarf which has not enough energy to "feed" the nebula. So they suspect that there is a undiscovered hot companion.
The nebula is in Lacerta, has an apparent size of 2' x 1.5' and has a surface magnitude of around 16.
The distance is also not exactly known. I did find 3300, 4200 or 4800 light years.
The capture has a FOV of 16' 23" x 09' 12" and a resolution of 0.517 arcsec/px.
Also a record for me: I also used the Optolong L-eNhance filter (Ha, Hb and OIII) with 240 second unguided exposures. Was a lot of tweaking of the mount settings and the polar alignment had to be spot on. The Ioptron CEM25EC mount just keeps on amazing me.
Bortle 7/8
Meade LX200 8 "f / 10 ACF OTA
Ioptron CEM25EC mount (no guiding)
Optolong L-Pro filter
Optec Lepus Standard 0,62x reducer
Captured with SharpCap Pro
Optolong L-Pro: 37 x 120 sec / Gain 120 / Offset 15 / White balance R50 / B50
Optolong L-Pro: 42 x 180 sec / Gain 100 / Offset 15 / White balance R50 / B50
Optolong L-eNhance: 20 x 240 sec / Gain 120 / Offset 15 / White balance R50 / B50
Each set stacked in DeepSkyStacker with darks, flats and darkflats and saved as FITS.
Then a stack of the 3 FITS files.
Processed in SiriL and Photoshop
SiriL: background extraction, photometric color calibration
Photoshop: shadows/highlights, levels, curves, noise reduction (Neat Image plugin), star reduction.
