iPolar works for me.
That said, I "center" the camera each time out.
Not an expert by any means, but my PHD tracking improved a great deal once I got the iPolar camera and software.
Posted 30 December 2020 - 03:39 PM
Posted 31 December 2020 - 02:43 AM
Posted 04 January 2021 - 06:36 PM
I have used my IPolar with the SkyGuider Pro mount and a different CF tripod for about the last year. Although I have often been frustrated with my alignment, it does not mirror your concerns. Most of what I have seen is a drift of original good alignment as the RA and manual DEC rotates around. I have found two issues causing this:
1. My WO Star71 and camera pushes 9# of an 11# rated mount. Balance, of course, is key - especially in my case, but often very difficult to accomplish, A good static balance in one DEC position is not necessarily a good balance in a DEC,say, 25degress different.
2. My tripod and the soft ground I have to set up on where I shoot complicates matters during a long shoot, i.e., alignment drifts. I have alleviated it somewhat by using a rock bag suspended from the tripod legs.
What works for me is to align early and often. I align once I am balanced, again once I have the target locked in, and again about every 20-30 150 second exposures. If I am vigilant, I get good, round stars most of the time - without guiding, but using a f/4.9 scope. In my experience, the IPolar is a good unit.
But I don't think this is your issue, if you guide well with SharpCap and not with IPolar.
My thought is to re-install your IPolar - I don't think that voids the IPolar or the SkyGuider Pro warranties - they are two separate units, two different SKU's, etc. a loose screw or a burr on a machined might be causing an issue.
Just my thoughts....
Posted 13 January 2021 - 09:32 PM
Just to add one more experience here, I have a CEM40EC, purchased in March 2020. I always align using iPolar and then check/tweak it with SharpCap Pro. My experience is that the iPolar will give me an alignment about 4 arc-minutes "off," according to SharpCap. Since I want the alignment to be as perfect as possible, I generally use the iPolar to get "in the neighborhood," and then use SharpCap to get it as close to zero as possible.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
