Omegon Camera veTEC 533 C Color
136 replies to this topic
#1 Euripides
Euripides
  • Loc: Thessaloniki - Greece
Posted 11 December 2020 - 03:13 AM
Hello!
Anyone heard-seen-used this camera ?
As far as I can see is the same just like the ASI533MC Pro, only with different branding (and price, at least for Europe).
#2 jiawen
jiawen
Posted 21 December 2020 - 10:43 AM
I'd also love to see a review of this camera. In terms of stats, it looks exactly the same as the 533MC Pro, but significantly cheaper. Does that mean it's missing something compared to the ZWO version?
#3 melodasi
melodasi
  • Loc: Nummela - Finland
Posted 11 January 2021 - 01:11 AM
I just bought this camera, but not yet received. I will try to write my impressions after I get it.
I had considered the ZWO ASI 533, but I have decided the bet on this Omegon, even though the sensor is the same, the software in the formware is probably quite different, but since we can change camera parameters anyway then in this respect i think it is ok.
My main fear is the quality and some driver compatibility, but also my first ZWO I had to return after a week due to TEC problems.
  • Hobby Astronomer and Euripides like this
#4 syberand
syberand
Posted 16 January 2021 - 05:28 AM
Hi, is there an update to how it is going? I am also looking at Omegon cameras. As far as I have been able to discover, they are rebranded Touptek, which other manufactors also use.
#5 melodasi
melodasi
Posted 16 January 2021 - 06:40 AM
Quick update... I got the camera last thursday, it looks really nice, very good quality externally, at least better then my old ZWO ASI178.
On Thursday i had tried to shoot with it, but it was -24 degrees and it was very challenging, the mount and the computer (that I keep externally) did not work well. But I was able to have a couple of shots taken, no ampglow and it appeared quite clear (5 min), it worked well with the provided ASCOM driver. I had just one challenge, when the camera settings were with 8 bits some times the image did not appear, not sure why maybe something related to the computer, the connection, driver...etc, but when I set it to 14 bits (which I will be using anyway) I had no problems, I will try to shoot again in the next few days and update you guys.
I have added a quick unboxing here:
https://www.youtube....h?v=AYnl1HbIUnk
  • Hobby Astronomer, acommonsoul, jiawen and 1 other like this
#6 Euripides
Euripides
Posted 16 January 2021 - 02:06 PM
Looks very interesting!
I am thinking that this will be my step forward from my modded canon. In addition to that I’ve seen an adapter “Astronomik Adapter EOS-Clip / M48” so if it will possible to use my current clip in filters with this camera and my lenses, I’m just a click away from my purchase :-)
Sent from my iPad using Tapatalk
#7 melodasi
melodasi
Posted 16 January 2021 - 02:35 PM
:-) as I am writing I am just imaging right now and I am strugling with the set, by default the ASCOM set for gain is 100 which is the limit, but then if I take 30 second exposure it gets totally blown, so right now I am just trying decreasing it little by little and testing everything else. So once I get this all figure out I will let you guys know.
Yes the camera is quite interesting.
  • Euripides likes this
#8 syberand
syberand
Posted 16 January 2021 - 05:55 PM
I'm looking at both the 16000 (old sensor) and the 533. I like the bigger size of the 16k. But newer sensor is better. I don't know.
To combat cold hardware. I have it in a box with towels and warm water :)
#9 melodasi
melodasi
Posted 17 January 2021 - 06:40 AM
Hey,
Last night was quite cold again -22C, but actually the whole gear performed quite well, the computer I had to put in a little carton box with some foam, and it worked out.
About the camera, it worked quite nicely, the only one thing that I changed from the "native" ASCOM drive configuration was the raw it size from 8 to 14 bits other then that nothing else, the gain I changed in SGP pro to 105 and it worked very well with 5 min exposures. I have attached here the settings and a link where you can download a few files of the Pleiades, Triangulum Galaxy and Spider Nebula, all of them are 5 min exposures at -20
https://drive.google...uE9?usp=sharing
I really like the camera, the shots were quite clear and amp glow free, I cannot say much about the cooling because the sensor was at -20 with no cooling :-), so I need to wait a better weather.
  • acommonsoul likes this
#10 syberand
syberand
Posted 17 January 2021 - 09:38 AM
Thanks for sharing. Currently it is the 533 i'm looking at. The big question is if will be the zwo or omegon. It is quite a pricejump
#11 syberand
syberand
Posted 17 January 2021 - 09:57 AM
Hey,
As someone not used to these type of files and used to using DSLR. After stacking I see basically no nebulosity.
#12 melodasi
melodasi
Posted 17 January 2021 - 10:44 AM
Yeah, think that there not enough exposures...maybe.
This is what I got with the Pleiades.
#13 melodasi
melodasi
Posted 17 January 2021 - 10:51 AM
Yes, I had the same dilemma, I talked with the guys from Astroshot.eu and they told me that from ZWO I might get a better support if I find some software bugs, but I decided to try at the end if it doesn't work I can return.
So far so good, I will wait for better skies here and try to have as many exposures I can get.
Cheers
  • syberand likes this
#14 syberand
syberand
Posted 17 January 2021 - 12:06 PM
Cheers
I will keep an eye on the thread and your progress
#15 syberand
syberand
Posted 23 January 2021 - 04:56 AM
Had more clear skies?
#16 melodasi
melodasi
Posted 23 January 2021 - 09:25 AM
Nope, terrible weather.
#17 Shimonu
Shimonu
  • Loc: Sweden
Posted 27 January 2021 - 09:55 AM
I'm also looking at this camera and I would love to know if anyone has tried it on a Linux system using kstars/Ekos
#18 Euripides
Euripides
Posted 27 January 2021 - 03:51 PM
Today I had a contact with astroshop for the exact same reason: to find out if the camera is compatible with the Ekos (I use Astroberry at the moment).
The guy who responded back, informed me that he personally uses the same camera with a StellarMate without any issues.
#19 Shimonu
Shimonu
  • Loc: Sweden
Posted 27 January 2021 - 05:53 PM
Does that mean you're placing an order? I would love to hear about your experience.
I saw your thread on the indi forum when searching about the camera and there was one guy there saying he tried the camera on his Mac and using Ekos without success. That could be a Mac specific problem though. So if you place an order and try it, it would be great to hear about it. :)
#20 Euripides
Euripides
Posted 28 January 2021 - 04:36 AM
I saw your thread on the indi forum when searching about the camera and there was one guy there saying he tried the camera on his Mac and using Ekos without success. That could be a Mac specific problem though. So if you place an order and try it, it would be great to hear about it. smile.gif
After reviewing the melodasi's files from 533 and compare them with my current setup (Canon 77D modded) I was sold.
Especially the darks. (Left 533, right 77D. My Canon's dark says 12deg, when the ambient temp was -6deg, the lowest I've ever seen)
In addition with that, the astroshop's response for Raspberry and Ekos, made me to order it :-)
PS. I am gonna report back for sure. But at the moment I have to wait till 15/2 cause there is no stock.
PS2.
Omegon 533 = 854euro
ZWO 533 = 1118euro
So yeap, I took my chances :-)
Edited by Euripides, 28 January 2021 - 04:38 AM.
#21 jerr
jerr
  • Loc: Czarny Las, Poland
Posted 28 January 2021 - 06:12 AM
There is also a RisingCam version of this camera at $900/€761:
https://www.aliexpre....4e9e243fCqqnFp
and Imageview at $9854€722 if that was not enough:
https://www.aliexpre....4240603aLMOoSj
What's interesting both above mentioned brands get positive feedback from CN users that have courage to buy them.
Edited by jerr, 28 January 2021 - 06:12 AM.
#22 syberand
syberand
Posted 30 January 2021 - 08:45 AM
I ended up going with the ZWO version. I have had too many problems with bad support and don't wish to waste too much of clear sky time on stuff acting up. But lets see.
#23 melodasi
melodasi
Posted 03 February 2021 - 03:18 PM
I ended up going with the ZWO version. I have had too many problems with bad support and don't wish to waste too much of clear sky time on stuff acting up. But lets see.ZWO is great
ZWO is great I almost bought it, but my adventure spirit spoke louder and I got the Omegon, so far so good even though the weather here is not helping.
#24 Euripides
Euripides
Posted 03 February 2021 - 04:11 PM
"What do you hear?"
"Nothing but the rain, sir"
Just landed!
So far so good.
1. Balance  - Ok
2. Drivers setup etc. with Raspberry Pi, Astroberry, Ekos - Ok
3. Fan & cooler work ok. At least for the past 30 minutes the cooler is steady at -10. (I'm inside with +24).
  • Dzukielis and 10Micron26 like this
#25 melodasi
melodasi
Posted 03 February 2021 - 04:19 PM
"What do you hear?"
Just landed!
So far so good.
1. Balance  - Ok
Congratulations. One thing that I noticed with the my VeTEC 533 that was different with my ASI, was that the fan just starts when the cooling starts where with the ASI the fan starts everytime you plug the power
