MOUNT FROM MEADE DEEP SPACE TELESCOPE PROBLEM
10 replies to this topic
#1 RonLevandoski
RonLevandoski
Posted 31 December 2020 - 11:35 PM
Good evening and Happy New Year!
I have a next door neighbor kid and his parents who picked up an old vintage Meade DS-10. The young kid is really interested in astronomy and this scope is a big deal to him and his sister.
It's actually in remarkably good condition, the only problem is that the top of the pier that allows for polar elevation adjustments is broken. You can see the crack in the image.
I looked into repairing it with aluminum welding and apparently the casting does not weld very well and would not be satisfactory. So, it appears that we need a replacement.
Does anyone have any suggestions on how to proceed ?
Thanks in advance.
ron Levandoski
#2 Augustus
Augustus
    Vendor
Posted 01 January 2021 - 12:11 AM
Might have it in my basement. I'll look today.
#3 chuckyou
chuckyou
Posted 01 January 2021 - 12:24 AM
you can braze cast iron
#4 B 26354
B 26354
Posted 01 January 2021 - 02:04 AM
But it's cast aluminum.
#5 DLuders
DLuders
Posted 01 January 2021 - 02:12 AM
You could attempt to repair it using some of the techniques in this previous Cloudy Nights Forum topic.
#6 clamchip
clamchip
Posted 01 January 2021 - 11:12 AM
I would use Super Glue.
Loctite brand, water thin.
Don't try cleaning the break.
As long as the oil from the threads has not migrated onto the break.
Don't touch the break with your fingers.
If the break is contaminated - game over.
Test fit the 2 parts to see if the grains of aluminum key together well.
If they don't key together don't bother trying glue.
If they do key together apply glue and push together and hold 2min, allow 24hr cure.
#7 Stevegeo
Stevegeo
Posted 01 January 2021 - 12:23 PM
Could you send me a few measurements  of the base Outside diameter that fits inside the tube ,
A drawing with measurements  of the ears ( height) and hole diameter .
I may have one.. or better yet MAKE YOU ONE OF STEEL .  Cheap . I work in a fab shop. Things like this are cake to make .
DM me if you get stuck .
Stevegeo
#8 Geo.
Geo.
    Vendor - Nexstar Parts
Posted 01 January 2021 - 01:03 PM
Or make a mending plate from some 1/4-3/8" aluminum, tap and thread the cast pieces and run screws threw the plate to the cast. Bore for the pin.
Take the bits to a foundry and have then cast a nice one in bronze.
#9 Gil V
Gil V
Posted 01 January 2021 - 01:28 PM
I would bolt up the mount and then use plate stock and some hardware to reinforce it. It doesn’t move much, so as long as it’s immobile and sturdy, you’ll be fine.
#10 clamchip
clamchip
Posted 01 January 2021 - 06:45 PM
This repair is mentioned before in this post but I'm thinking
how about go to the hardware store and buy a big washer.
Glue the parts together to hold them in place.
Clamp the washer over the break, drill 4 holes all the way
though the washer and casting.
Tap the holes in the casting and enlarge the 4 holes in the
washer so the screws pass through into your threaded
holes.
Robert
Edited by clamchip, 01 January 2021 - 06:47 PM.
#11 Tenacious
Tenacious
Posted 02 January 2021 - 12:11 PM
If you can replace the top cap, that's probably the best option.
Short of replacement, I would be tempted by the mending ideas:
  1  Glue it together as Roberts says.
  2  Sister-on a mending plate, except make it the same shape and as large as the original tab.  To attach the mending plate, maybe tap the holes down low where the original casting has more "meat" and is undisturbed.
  3  Buy a longer pivot bolt to go though the whole assembly and put a steel nut and washer on the end of that.  The nut will allow enough clamping force.  Over-torquing the pivot bolt might be what caused the crack and failure of the original casting.
  4  After painting it black, it should look pretty good and be as strong as the original casting.
Edited by Tenacious, 02 January 2021 - 12:39 PM.
