Which guide scope for Deep Sky AP
14 replies to this topic
#1 crozen
crozen
Posted 04 January 2021 - 09:06 AM
This is my setup :
Scope : TS Optics AP 102/520 6-Element-Flatfield Imaging Star OTA
Mount : Skywatcher NEQ-6 Pro Goto
Imaging : modified EOS Rebel T4i DSLR
Autoguiding : ZWO ASI 120 MC Color camera.
Question : What good guide scope do i need for autoguiding with the ASI 120 MC ?
Thnx !
#2 meansrt
meansrt
Posted 04 January 2021 - 09:22 AM
You've not got a huge focal length so you can easily get away with the ZWO mini guide scope or maybe one at 250mm focal length like the Evoguide 50ED. If I were you I might switch to a monochrome guide cam though I'm sure the color will work just fine.
#3 jonnybravo0311
jonnybravo0311
  • Loc: NJ, US
Posted 04 January 2021 - 09:40 AM
Here's a formula to help you determine whether your main cam/scope and guide cam/scope will work well together:
(FL_main/FL_guide)*(PX_guide/PX_main) where FL = focal length and PX = pixel size.
Get an answer < 3 and you're in a good spot.
Example:
WO GT81 with 0.8x reducer = 382mm
WO 50mm guide scope = 200mm
ASI 294MC = 4.63
ASI 120MM Mini = 3.75
(382/200)*(3.75/4.63) = 1.55
Therefore, the above is a great combination.
Edited by jonnybravo0311, 04 January 2021 - 09:45 AM.
  • polslinux likes this
#4 crozen
crozen
Posted 04 January 2021 - 10:53 AM
Example:
ASI 294MC = 4.63
Will this be good ?
TS Optics 102/520 = 520mm
TS Optics 80mm guide scope = 328mm  https://www.teleskop...al-focuser.html
DSLR = 4.29 µm
ASI 120 MC Color = 3.75 µm
(520/328) * (3.75/4.29) = 1.385
Edited by crozen, 04 January 2021 - 10:54 AM.
#5 jonnybravo0311
jonnybravo0311
  • Loc: NJ, US
Posted 04 January 2021 - 11:32 AM
Will this be good ?
DSLR = 4.29 µm
Just purely by the numbers? Yes, that's a good combination.
Most of the time people go with mono cameras for guiding (120mm mini and the like). You could use a smaller guide scope if you wanted. A 50mm would be fine as well.
#6 Rasfahan
Rasfahan
  • Loc: Hessen, Germany
Posted 04 January 2021 - 12:44 PM
I have good success with a 30mm guidescope and the 120mm (mono) for my apo (100/550 mm). The 50mm on the mc should work just fine.
Edited by Rasfahan, 04 January 2021 - 12:45 PM.
#7 SonnyE
SonnyE
  • Loc: Cali for ni a
Posted 05 January 2021 - 12:53 AM
I've been using my same Orion 50 mm guide scope all along.
I had the Orion SSAG camera for a lot of years.
But recently got a ZWO ASI290MM Mini. More stars, more detail.
I find that the telescope is one part of the equation, but the camera can make a big difference.
#8 moxican
moxican
  • Loc: Toronto, Canada
Posted 05 January 2021 - 02:25 AM
Example:
ASI 294MC = 4.63
This is spot on...
With a main/guide scope ratio that low, color or mono will not make any difference. I would not sweat it. Set up next time you have clear skies and shoot awaycool.gif
#9 Stelios
Stelios
  • Loc: West Hills, CA
Posted 05 January 2021 - 03:01 AM
Cheapest guidescope I know is the Orion 50mm. $79. Works fine too... Paying more won't get you more.
#10 sbharrat
sbharrat
  • Loc: NJ, USA
Posted 05 January 2021 - 07:15 AM
Happy with the Orion 50mm? Thinking of that as it is a bit lighter than some other similar choices but was wondering if any flex with the way it attaches. Thinking of pairing this with a ZWO ASI120MM...
#11 crozen
crozen
Posted 05 January 2021 - 07:29 AM
You are wrong.
There are other things which are also important. Having a focuser in front of the scope (the cheap Orion 50 mm) is really a hell ! Also that mount is not accurate.
#12 meansrt
meansrt
Posted 05 January 2021 - 09:51 AM
You are wrong.
I dont think the focuser will be that much of a problems since Ideally you can just set it and forget it. The accuracy of the mount ( I assume you're talking about the thumbscrews? ) shouldn't actually matter very much. This is because the guiding software will account for the guide scope being slightly out of line with your telescope anyway when it does calibration.
#13 jerr
jerr
  • Loc: Czarny Las, Poland
Posted 05 January 2021 - 10:58 AM
There are even cheaper clones of tiny ZWO guidescopes available straight from China:
https://www.aliexpre....75334f1501UB2B
Shipping cost is nothing or close to nothing depending on a vendor. I’ve ordered one and waiting for delivery. Should be with me tomorrow after 18 days of waiting. I plan to us it with my ZS66 but will give it a try also with APO127 - fl.950 even though pixel scale calculation gives me result slightly above 5.
#14 charlieb123
charlieb123
  • Loc: New York
Posted 05 January 2021 - 11:36 AM
SVBony 50mm guide scope is the same as the Orion 50mm scope.
As long as all the thumbscrews are locked down it works well. Make sure it's solidly mounted.
#15 crozen
crozen
Posted 09 January 2021 - 03:45 PM
Guys, what do you thing about going this way for more tracking precision : OAG with the ASI 120MC ?
The bad thing is that the camera is not monochrome, so, less sensitive but maybe it works !
Has anyone tried ?
I'm in Bortle 6.
Edited by crozen, 09 January 2021 - 03:47 PM.
