Finder Shoe for AT60ED?
accessories equipment refractor
25 replies to this topic
#1 Sarkikos
Sarkikos
  • Loc: Per sylvam ad astra
Posted 07 January 2021 - 09:17 AM
AFAIK, the Astro-Tech Finderscope Mounting Shoe (ATSHOE) is the only finder shoe that will fit the AT60ED.  Unfortunately, it virtually never seems to be in stock.  And when it does come back in stock, I've always missed reordering it.  shrug.gif
Astro-Tech Finderscope Mounting Shoe  https://www.astronom...nting-shoe.html
Does anyone know of an alternative finder shoe that will fit the AT60ED?  I know some would call the AT60ED a finder - and it could be used as one.  But I like to have at least a laser finder on a telescope, no matter how small it is.  It makes for much quicker and easier sighting of the object.
Edited by Sarkikos, 07 January 2021 - 09:55 AM.
#2 qswat72
qswat72
Posted 07 January 2021 - 09:30 AM
I’m in the same boat as you, looking for a finder shoe. Hope to hear some good responses!
  • Sarkikos likes this
#3 Joe Bergeron
Joe Bergeron
    Vendor - Space Art
  • Loc: Upstate NY
Posted 07 January 2021 - 09:46 AM
The Astro-Tech shoes are identical to many sold by other outlets, including Astromania, which can be found on Amazon. I bought a couple of those when I had difficulty getting them from Astronomics.
  • Larry Adams and BFaucett like this
#4 Sarkikos
Sarkikos
Posted 07 January 2021 - 09:49 AM
Will they fit the AT60ED specifically?  I've tried other finder shoes from other companies, and they won't fit the AT60ED.  IIRC, the main problem is that the other shoes are too high.  It's been awhile since I've visited this problem.
Can you post a link to a finder shoe that you know will fit the AT60ED?
Edited by Sarkikos, 07 January 2021 - 09:51 AM.
#5 Sarkikos
Sarkikos
Posted 07 January 2021 - 10:00 AM
This finder shoe from Astromania looks like the Astro-Tech.  https://astromaniaop...pointer-bracket
The ad description at Astromania says "This specialized dovetail mounting base fits factory drilled holes on most Meade, C elestron, and Orion Schmidt-Cassegrain telescopes."  However, it also says it is a "unversal" finder shoe.
So will it fit the AT60ED?
Edited by Sarkikos, 07 January 2021 - 10:01 AM.
#6 cst4
cst4
Posted 07 January 2021 - 10:04 AM
The ones like this with 4 slots are great.  They fit everything I've tried to put them on.  Just need the right screws for your scope holes.
Edited by cst4, 07 January 2021 - 10:04 AM.
#7 Sarkikos
Sarkikos
Posted 07 January 2021 - 10:10 AM
The AT60ED includes screws already in the holes, but might need longer ones to connect the finder shoe.  Just don't use screws that are too long or you could mar the draw tube.
I didn't see the finder shoes at HPS.  Looks like they'll fit.
I already ordered a couple shoes through Alstar on Amazon.  Should arrive next Tuesday.
The ones at HPS are a buck cheaper.  But they want to charge at least $11.14 shipping.  Free shipping at Amazon, and I got a dollar off.
Edited by Sarkikos, 07 January 2021 - 10:14 AM.
#8 qswat72
qswat72
Posted 07 January 2021 - 10:13 AM
I already ordered a couple shoes through Alstar on Amazon. Should arrive next Tuesday. The ones at HPS are a buck cheaper. But I got a dollar off at Amazon. :shrug:
Might even be cheaper from Amazon. I believe you have to pay shipping for HPS as well.
#9 Sarkikos
Sarkikos
Posted 07 January 2021 - 10:17 AM
Yes, you're right about the shipping.  I found that out after I put a couple of the shoes in the cart at HPS.
#10 Sarkikos
Sarkikos
Posted 07 January 2021 - 12:07 PM
I'll put both finder shoes on the AT60ED, one for the left side, one for the right.  Overkill for a little 60mm?  Not if you want flexibility.
The optimal location for a finder might change depending on which mount the AT60ED is on.
Or I might want both a laser finder and a little 6x30 right angle finder.  I like to avoid a "finder eyepiece" in the telescope.  Especially when I'm observing double stars, where higher magnification is needed, I want to go right to high power without a preliminary low power "finder eyepiece."
Edited by Sarkikos, 07 January 2021 - 12:12 PM.
#11 Joe Bergeron
Joe Bergeron
    Vendor - Space Art
  • Loc: Upstate NY
Posted 07 January 2021 - 01:28 PM
I also put both on mine. They will usually hold a guide scope and an ASIair.
#12 qswat72
qswat72
Posted 07 January 2021 - 01:41 PM
This is currently my plan as well. I’d like to mount a guide scope, as well as possibly a Telrad on the two mounting points.
#13 Don Taylor
Don Taylor
  • Loc: Broken Arrow (Tulsa Area) Oklahoma
Posted 07 January 2021 - 09:12 PM
If you haven't found one yet - I believe this one is the same as the Astronomics offering:
https://agenaastro.c...nder-xfurb.html
I have purchased the one above and also the one from Astronomics and my samples are identical. I note that the small diameter of the AT60 focuser means the screws clamp the bracket to the focuser while leaving very small gaps between the "rails" along the edges of the bracket and the focuser itself. Both the Agena and Astronomics brackets do that.
The following one looks identical as well - but I haven't purchased this one so I can't confirm that:
https://agenaastro.c...bafm-st001.html
850 4700 4148
Edited by Don Taylor, 07 January 2021 - 09:13 PM.
  • Sarkikos, BFaucett and qswat72 like this
#14 Jaimo!
Jaimo!
  • Loc: 3rd Stone from the Sun
Posted 07 January 2021 - 10:26 PM
Mike, I have the WO Z61, same scope, different label.  I use the inexpensive 4 slot shoe as linked above, I believe I got mine off ebay, direct from SVbony in China.  I bought a bunch of them, couldn't have been more than 10 or 12 dollars a piece (maybe less).
Here's a close-up as I had this scope out this evening:
Here's the full kit:
  • Sarkikos and jerr like this
#15 Joe Bergeron
Joe Bergeron
    Vendor - Space Art
  • Loc: Upstate NY
Posted 08 January 2021 - 12:02 AM
Yup. What I did was stick some fuzzy Velcro on those rails or legs so they would contact the focuser body.
  • BFaucett likes this
#16 paulw617
paulw617
Posted 08 January 2021 - 09:44 AM
Thanks so much for the info.  Just ordered the Astromania from Amazon.  Arrives tomorrow.
  • Sarkikos and BFaucett like this
#17 Sarkikos
Sarkikos
Posted 12 January 2021 - 07:17 AM
The Alstar finder shoes from Amazon arrived yesterday, a day early.  I attached them to my AT60ED using the screws that were on the scope.  They are solid and secure, though the edges of the finder shoes do not contact the OTA.  I might or might not add some kind of base below the shoes to take up the slack.  Thick black, foam sheeting should do the trick.  But I'll only attach light finders to the shoes, like a laser finder, 6x30 RACI or red-dot finder.  So I really don't think it makes a difference.
At this point, I have two finder shoes on all of my refractors that can take two finder shoes.
Edited by Sarkikos, 12 January 2021 - 07:17 AM.
  • duck2k likes this
#18 jerr
jerr
  • Loc: Czarny Las, Poland
Posted 12 January 2021 - 08:06 AM
I was facing same challenge looking for a guide scope bracket for my old ZS66. Here is what I've found:
https://www.aliexpre....3c2634ecxged6O
https://www.aliexpre...3c00WqJju9&mp=1
What's important, a bottom part of the bracket is curved and may nicely fit (that is what I hope for) curvation of the focuser. So, potentially no scuffs and scratches.
I've placed on order for one of them and awaiting delivery. Will see in 3 weeks.
  • Jaimo! and Sarkikos like this
#19 Sarkikos
Sarkikos
Posted 12 January 2021 - 10:07 AM
The Alstar finder shoes from Amazon only contact the focuser of the AT60ED longitudinally.  There is a small gap between shoe and focuser laterally.  So there are no hard edges in contact with the focuser.  There would only be a chance of scuffs and scratches if the finder shoe was designed for a smaller scope.
Edited by Sarkikos, 12 January 2021 - 10:08 AM.
#20 paulw617
paulw617
Posted 12 January 2021 - 10:59 AM
I ended up getting the Everest Universal Dovetail Base from Amazon ($1 cheaper than the Alstar) and works great with my ZWO MiniScope attached to my AT72EDii.
#21 swsantos
swsantos
  • Loc: Rhode Island
Posted Yesterday, 11:57 PM
Found a great finder shoe for the AT60ED!
The PrimaLuceLab DX Finder Base.
https://optcorp.com/...airy-refractors
It has a curved base,
it matches the red details of the scope,
and the curvature closely matches the radius of the focuser.
Attaches with the stock hex screws that come on the focuser so no worries about too long and the screws that secure the finder have nice nylon tips.
  • Sarkikos, jerr, NC Startrekker and 2 others like this
#22 BFaucett
BFaucett
  • Loc: Houston, Texas
Posted Today, 12:14 AM
...<snip>...
Cool! I like the matching color. I think I'll order one. Thanks for the heads up.
Edit to add: I did order one.
Edited by BFaucett, Today, 02:52 PM.
#23 jerr
jerr
Posted Today, 07:05 AM
Nice!
I wish I spotted this before I ordered black ones :(
#24 Sarkikos
Sarkikos
Posted Today, 08:26 AM
Nice!
They all look the same in the dark.
The edges of the PrimaLuca red bases look like they don't contact the OTA.  Does this really match the curvature of the AT60ED?  Maybe it matches better than the black bases?
Edited by Sarkikos, Today, 08:30 AM.
#25 duck2k
duck2k
  • Loc: Fountain Hills, AZ
Posted Today, 11:28 AM
Just ordered one!:)
Also tagged with one or more of these keywords: accessories, equipment, refractor
