Goto Optical 3" Single (Mono) Axis 76mm 1200mm fl. Redux
15 replies to this topic
#1 Stew44
Stew44
Posted 10 January 2021 - 09:55 PM
In early 2019 I acquired what I thought was an orphaned (no mount) Goto 3" telescope in its case with accys.  I discussed its condition and my impressions here:
https://www.cloudyni...is#entry9615568
It turns out that I now believe it came over from Japan that way as certain features that are necessary for the mount to function are missing from this OTA.
I have only seen one other of these telescopes on CN (owned by strdst for the last twelve years) with mount.  The only other I've seen has been in pictures from the Japanese Telescope Museum.  I believe the mount in particular is rarer than the similar mount accompanying the 60mm Eros telescopes from the same period (roughly 1951-1954).  And a lighter weight yet mount was offered with a Comet OTA as the Castor.  All three of these dual pendulum counterweight mounts (Castor, Eros and this 3" Single Axis), matched with properly scaled OTAs, according to information on Galakuma's site, were designed by Goto-san's protégé Mr. Shusuke Kojima.
I encouraged strdst to post on this mount because it was built at a time where materials in Japan and machining capability were scarce.  That post is here:
https://www.cloudyni...is#entry9376701
I really didn't expect to ever find a mount for my OTA, but recently strdst quite generously offered me the opportunity to acquire the mount.  It arrived a couple days ago and I finally got things cobbled together.  This is the scope set up for for southern hemisphere to zenith.
As we will see this is fully functional as a single axis mount.  But as strdst noted, operating the mount is not intuitive.  It took a little time to sort out the differences between it and the similar Eros mounts I have.  Here it is setup for polar alignment using the OTA.
Edited by Stew44, 11 January 2021 - 09:12 PM.
  • astro140, mdowns, Terra Nova and 5 others like this
#2 Stew44
Stew44
Posted 10 January 2021 - 09:59 PM
Here is a closeup of the mount configuration:
Here to the west
And here to the east
It takes a bit to reconfigure from northern to southern hemisphere, and especially the pendulum weights need to be carefully kept out of the way during movement.
More to come as there are some wonderful features incorporated into this mount that are easily seen in follow-on Goto Optical products, and many Astro Optics and its derivative products as well.
Edited by Stew44, 10 January 2021 - 10:07 PM.
  • Paul Hyndman, CharlieB, astro140 and 11 others like this
#3 Bomber Bob
Bomber Bob
  • Loc: The Swamp, USA
Posted 10 January 2021 - 10:06 PM
Cool concept!  The only similar mount I've seen in R/L:  About 30 years ago, the BX (Base Exchange) started selling Galileo brand scopes, and at least one -- an 80mm Newt, IIRC -- used a pair of pendulum weights.
(When I first joined the USAF, the BX sold some top-tier Japanese scopes -- Nikon, Pentax -- but by the 1990s, ROC-made brands like the Galileo replaced them.)
Edited by Bomber Bob, 10 January 2021 - 10:14 PM.
  • Stew44 likes this
#4 PawPaw
PawPaw
  • Loc: West Central Missouri
Posted 11 January 2021 - 09:58 AM
Stew I know how difficult it can be to make complete an orphaned OTA or mount and keep it original.  Absolutely  a fascinating design.
Can you explain the process of changing it from an equatorial mount to an Alt-azimuth?
Don
  • Stew44 likes this
#5 Stew44
Stew44
Posted 11 January 2021 - 10:19 AM
That's really pretty straight forward.  Just adjust the RA axis to vertical as in this picture and Dec mechanism to level the OTA.  The biggest challenge is figuring out which levered nut to loosen to adjust which part of the assembly.  Haven't figured out if I can separate the RA drive gear from the Dec mechanism to better position the cable extension (the school mounts allow this as BB has pointed out in previous posts).  But there are no setting circles so more convenience than need.
Edited by Stew44, 11 January 2021 - 10:59 AM.
  • RichA, Terra Nova, Bomber Bob and 2 others like this
#6 Defenderslideguitar
Defenderslideguitar
  • Loc: Connecticut
Posted 11 January 2021 - 10:38 AM
Sweet.  We just love it when a rarer  classic comes together. Cool design for sure
#7 Stew44
Stew44
Posted 11 January 2021 - 02:05 PM
The Single Axis 3" was apparently marketed through 1959.  Maybe they simply had mount inventory and because it wasn't a school telescope it didn't need to fit that formula for acceptance.  For whatever the reason it was updated after that time to 80mm f/15 and the mount(s) developed for the 4" were transitioned to the 3".  Here is my Mod 203 from early 60's.  Goto liked the leg set and called this the Field Tripod.  Compare with the lower picture.
Edited by Stew44, 11 January 2021 - 05:58 PM.
  • astro140, Terra Nova, Bomber Bob and 2 others like this
#8 RichA
RichA
  • Loc: Toronto, Canada
Posted 11 January 2021 - 03:03 PM
What a unique counter-weight system.
#9 clamchip
clamchip
  • Loc: Seattle
Posted 11 January 2021 - 03:52 PM
Edmund Scientific was selling Goto in the early days.
This Eros? mono axis Edmund ad is from late 1952:
Robert
Edited by clamchip, 11 January 2021 - 03:53 PM.
  • Paul Hyndman, astro140, Terra Nova and 4 others like this
#10 dave brock
dave brock
  • Loc: Hamilton, New Zealand
Posted 11 January 2021 - 05:34 PM
Why is it referred to as a single axis mount?
#11 Stew44
Stew44
Posted 11 January 2021 - 05:51 PM
Typical mount today and on the 60's 3" above has two axes - RA and Dec.  So twice machining required for mount.  This one only has an RA axis.  Dec is a limited screw tilt mechanism riding on  the CW axis.  Has limited range of movement.
#12 dave brock
dave brock
Posted 11 January 2021 - 06:15 PM
So being pedantic (which I'm often accused of) it has two axes but limited slow motion in dec?
#13 Kasmos
Kasmos
  • Loc: So Cal
Posted 11 January 2021 - 08:18 PM
Stew, Your win but I can't understand why Keith would separate his OTA from the mount. I'm I missing something?
#14 Stew44
Stew44
Posted 11 January 2021 - 09:03 PM
Yes in a nut shell.  The pivot pin and tilting mechanism doesn't require all the machining effort full Dec axis assembly would require.  I guess Goto didn't feel the pivot pin was a true Dec axis in the same vane as the Dec axis assembly in a typical dual axis GEM.
#15 strdst
strdst
  • Loc: Oregon Territory
Posted 11 January 2021 - 09:49 PM
The devil made me do it.
Seriously, (and serious doesn't come easy for me), to provide (sell) an unobtainable item to complete a telescope in Stew's, (a true Goto scholar) collection feels terrific! My win as well! One complete telescope and one incomplete telescope becomes one incomplete telescope and one complete telescope...zero sum gain?
  • Kasmos likes this
#16 Dave Trott
Dave Trott
  • Loc: Colorado
Posted 11 January 2021 - 11:02 PM
What a wonderful scope and fascinating mount! Congratulations, Stew!
- Dave
