EQ6R with a slewing problem
4 replies to this topic
#1 Ngaz
Ngaz
Posted 13 January 2021 - 04:43 PM
I am experiencing a problem slewing west.  More specifically, the mount will not slew west when the rate is set to 1 on the hand controller.  It moves correctly at rates 2-9.
If anyone has suggestions or can point me to a discussion of this problem I would appreciate the information.  Search engines haven’t yielded guidance.
#2 RonaldNC
RonaldNC
  • Loc: Fuquay Varina, NC
Posted 13 January 2021 - 05:58 PM
Ngaz,
Are you sure that you have taken up any backlash.  That rate is so slow that it could take a couple of seconds for it to reverse direction.
Ron
#3 Ngaz
Ngaz
Posted 13 January 2021 - 06:41 PM
I am. I've run it up to two minutes in both directions and that direction won't go. I even tried to goose it (help it get started since it moves at the other rates).
#4 RonaldNC
RonaldNC
Posted 13 January 2021 - 08:07 PM
Cool.  Does the "1" key work for other things... like setting the time, location, etc.  Wondering if the key itself has a problem.
If the physical key is not the problem, it may be time to contact Sky-Watcher.
Good luck!
Ron
#5 Ngaz
Ngaz
Posted 13 January 2021 - 10:04 PM
The other three directions move at the 1 rate. I think you're right about contacting Sky-Watcher. Thanks for looking at my issue.
