Samyang 135, Canon 6d, problems with flat background.
optics equipment dslr astrophotography
11 replies to this topic
#1 qendis
qendis
Posted 13 January 2021 - 04:45 PM
Hello!
For quite some time, I have been looking for a solution to the problem of a strip, which appears at the bottom of the picture. The strip is visible when the histogram is streched.
I use the following setup: Canon 6d, Samyang 135mm (both new). However, I encountered the exact same problem with another similar setup, namely a used Samyang 135 and a Canon 6d.
I tried to use various types of flats (proper exposition, overexposition, long exposure time). Nothing seems to help.
I stacked the photos in Siril, DSS, APP and PIX and the result is still the same. I can't find a solution anywhere.
Do you think the problem is with the camera or the lens?
I'd appreciate any advice or suggestions you could give me.
Best regards,
#2 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 13 January 2021 - 05:01 PM
Does it happen on other lenses?  You should give it a try.  What about different ISO's?  Have you tried PI 'CanonBandingReduction'?
Is the banding in the RAW images?  How do you take your Flats?
Edited by Jim Waters, 13 January 2021 - 05:13 PM.
#3 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 13 January 2021 - 05:23 PM
Personally I would take another series with the camera at a different orientation because that line does not look straight.
#4 Cfreerksen
Cfreerksen
  • Loc: Tooele, Ut
Posted 13 January 2021 - 05:32 PM
Are you talking about the horizontal line at the bottom of the image? Are you plate solving after a meridian flip? Or maybe you are seeing a problem that has been documented in Canon cameras. Search "Canon Banding" I don't use DSLRs often so you might want to take a look into the posts.
Chris
#5 t-ara-fan
t-ara-fan
  • Loc: 50° 13' N
Posted 13 January 2021 - 07:48 PM
That line is the shadow of the mirror on the sensor.  It is most pronounced with fast lenses = fatter light cone coming into the sensor.
https://www.cloudyni...shadow-or-what/
Solutions: stop down the lens, crop the image, remove the mirror from the camera.
I just crop. My f/1.4 lens isn't that great off axis when wide open.
Edited by t-ara-fan, 13 January 2021 - 07:48 PM.
  • qendis likes this
#6 Jim Waters
Jim Waters
Posted 13 January 2021 - 07:54 PM
Here's an image with the same setup.  I had no banding in the RAW images and no issues with processing.  BIAS, Flats and Darks were taken.
https://flic.kr/p/2grP49d
EDIT - Shot at f/2.8
Edited by Jim Waters, 13 January 2021 - 07:55 PM.
  • qendis likes this
#7 michael8554
michael8554
  • Loc: Wiltshire UK
Posted 14 January 2021 - 05:18 AM
It's not clear to me whether the bright-up is on the Raws or just on the stacked image ?
I would carefully examine a stretched Light and a stretched Flat.
If those are clear then possibly the bright-up is due to the stacked result of images that are drifting slightly in Dec over the length of the session.
  • qendis likes this
#8 qendis
qendis
Posted 14 January 2021 - 10:49 AM
There is no banding in the light frames.
I make flats from 1200 / s to 1.6 s. I am just trying different variants.
#9 qendis
qendis
Posted 14 January 2021 - 11:11 AM
Chris
Thank you for your help. I did as you say. I have some new ideas.
Chris
#10 fishonkevin
fishonkevin
  • Loc: Michigan
Posted 15 January 2021 - 08:57 AM
Do you block the cameras viewfinder?  It may be a light leak.
#11 qendis
qendis
Posted Today, 09:02 AM
Yes, I block the camera viewfinder. I am using black insulating tape.
#12 qendis
qendis
Posted Today, 09:09 AM
Welcome! I removed the strip from the photo.
I used a flat 0.8 s / ISO 100. Thus, the flat fixed the problem.
Thank you for all your help.
Greetings from Poland!
Also tagged with one or more of these keywords: optics, equipment, dslr, astrophotography
