Visual Backs
4 replies to this topic
#1 Deepskyclusterstruck
Posted 17 January 2021 - 07:00 AM
What is the difference between a visual back and an eyepiece adaptor and are visual backs always explicitly marked as such? Of the telescopes I have seen only my Schmidt Cassegrain 6SE has printed explicitly on the part in question "visual back." The purpose seems identical to a 2 to 1.25 inch eyepiece converter with the exception that the diameter of the drawtube seems too narrow to fully accomadate 2 inch diagonals & eyepieces.
Are the terms "visual back" and "eyepiece adaptor" sometimes used interchangeably?
#2 SloMoe
SloMoe
  • Loc: Washington State
Posted 17 January 2021 - 08:19 AM
Morning, no, not really, a visual back is used to hold the glass path optic's, diagonal and or eyepiece,
and eyepiece adapters are used to be able to use a smaller diameter eye piece for a larger eyepiece holder in a focuser, like the most common 1.25" to 2" adapter.
Visual backs thread onto the baffle tube of the Mak  or SCT , eyepiece adapter's fit into eyepiece holders of focusers..
So if your scope has a 2" focuser eyepiece holder you'd use a 2" to 1.25" eyepiece adapter, there are variations of these, like .956"  to 1.25" or .956" to 2" or even 2" eyepieces to a 1.25" eyepiece holder..
Some Mak's use a different thread size & pitch than that of most SCT's and you can get thread adapter's for those too, to change the Mak thread to the standard SCT thread visual back
Here's a link to a vendors site that lists most of the common eyepiece adapters.
https://agenaastro.c...s/adapters.html
And here's a link to their visual back page.
https://agenaastro.c...apters.html?p=2
Edited by SloMoe, 17 January 2021 - 08:20 AM.
  • descott12 likes this
#3 junomike
junomike
  • Loc: Ontario
Posted 17 January 2021 - 08:21 AM
Not usually.  A Visual Back is attached to the back of an SCT or Focuser (Refractor/Newt).  These almost always have a 2" opening to accept accessories (Diagonal, Barlowa, Etc).
An eyepiece adapter takes that 2" opening and stops it down (adapts) it to accept 1.25" eyepieces.
I can see how someone might confuse a 1.25" visual back with a 2" - 1.25" adapter but the threads are different as the  VB will have SCT threading and the adapter will have 2" threading.
#4 Deepskyclusterstruck
Posted 17 January 2021 - 12:53 PM
Thank you both.
#5 Deepskyclusterstruck
Thank you both.
