Skywatcher azeqr pro ra shaft replacement
equipment
5 replies to this topic
#1 DarKnight101
DarKnight101
Posted 18 January 2021 - 11:07 PM
Hi All.
after trashing my RA shaft during disassembly  does anyone know where i can obtain a replacement shaft?
Desperate.
#2 Couder
Couder
  • Loc: Mansfield, Missouri in the Ozarks
Posted 18 January 2021 - 11:25 PM
I have replaced many shafts in EQ mounts with stainless steel rod, if you decide to do this or replace with an original I suggest take many pictures (easily deleted later) of current look and then disassembly form many angles - along with notes. It is too easy to think you will remember later, only to find you have to take it apart two or three times to put in a piece you forgot.
#3 DarKnight101
DarKnight101
Posted 19 January 2021 - 01:05 AM
Thanks for the quick response.
I would like to use an original shaft.
I'm looking at the damage on the housing thread but think i can clean it up some and still have more than two thirds of ok thread to work with.
The cap nut is in much better condition.
#4 Couder
Couder
Posted 19 January 2021 - 09:36 AM
You can buy dies to match the thread (I would use a little lubricant) or you can buy a "thread file" which has cuts to match 8 different threads. Just search for thread file. These are handy when you cannot get a die to start. You will need to hold the shaft while threading - I use my vise, but I put pieces of thin wood on each side so the vise jaws do not leave marks on the shaft.
Edited by Couder, 19 January 2021 - 09:42 AM.
  • Applal likes this
#5 EFT
EFT
    Vendor - Deep Space Products
  • Loc: Phoenix, AZ
Posted 19 January 2021 - 11:45 AM
Can you post a photo of the damage.  I can't picture how you have damaged the shaft.  This is not something you will find anywhere except Skywatcher and then, it is not a stocked part as far as I know so it will take a long time to get.  I you try to have one made, remember that the shaft has a stop on the end so that it does not slide all the way out of the housing.
#6 georgian82
georgian82
  • Loc: Healdsburg, California
Posted 20 January 2021 - 01:49 AM
Geoptik makes replacement shafts. You will have to check it fits your model
https://m.youtube.co...h?v=UJusAu1zZMM
Also tagged with one or more of these keywords: equipment
