Sky-Watcher Star Adventurer 2i -- Wifi Range
7 replies to this topic
#1 cameron12x
cameron12x
  • Loc: Cincinnati, Ohio
Posted 19 January 2021 - 10:52 AM
Does anyone know of the range of the Wifi on this mount?  10'?  50'?  Other?  TIA!
#2 qswat72
qswat72
Posted 19 January 2021 - 10:55 AM
I’d say it’s around 10’. Doesn’t work great at a distance, or if there are objects between you and the tracker, but if you are nearby it works great and is quite a useful feature.
#3 cameron12x
cameron12x
Posted 19 January 2021 - 11:06 AM
Have you ever used it from a car with the engine turned on?  Would the vibration of a nearby car affect tracking?
#4 qswat72
qswat72
Posted 19 January 2021 - 11:26 AM
I have not, however I think you’d be able to park far enough to avoid vibrations. You don’t have to be constantly connected for the mount to run either, so you can set it up using the WiFi, then head to a car parked a bit further away.
  • cameron12x likes this
#5 Soundboy121
Soundboy121
Posted 20 January 2021 - 10:58 PM
Hello i am new to CL
 i got this for Xmas
...i am a Newbie...
my wifi drops even when its right next to me? i haven't gotten but maybe 2 minutes of constant connectivity before it drops out ???
which app is used to control the mount from iOS? SAM,SynScan/pro??
any help is appreciated
#6 qswat72
qswat72
Posted 21 January 2021 - 12:53 AM
i got this for Xmas
...i am a Newbie...
I’m on iOS as well and haven’t had really any issues. I use the SA Console app (also known as the SAM console app but renamed recently).
#7 Soundboy121
Soundboy121
Posted 22 January 2021 - 04:33 PM
so the problem i had was fixed bu switching power supply to fresh batteries  ....the machine would power up but when a slew command was sent guess there wasn't enuff juice to do both??
is there a way to monitor battery percentage on the app?
#8 qswat72
qswat72
Posted 22 January 2021 - 04:49 PM
The app tells you how how many volts the mount is using. It can be found in the bottom right corner. Once it drops below around 4.6V the mount will start having issues. I’ve started running my mount through the USB connection which has gone good so far.
Edited by qswat72, 22 January 2021 - 04:49 PM.
