Line filters vs tri/quad band filters
4 replies to this topic
#1 stars n planets
stars n planets
Posted 19 January 2021 - 02:08 PM
Hi
Would the Ha collect from a 12nm Ha only filter be better than any Ha collected by a tri/quad filter that collects O and S data?
#2 bobzeq25
bobzeq25
Posted 19 January 2021 - 02:22 PM
Easiest question ever.
The line filters are designed to work with mono cameras, the tri/quad band are designed to work with one shot color.  That is the determining factor.
Using line filters with OSC, or tri/quad band with mono, is a bad idea.  It can work some, but it's still a bad idea.  Inefficient use of each.
Mono plus line filters is better than OSC with tri/quad band.  But more expensive.  That's an easy determination, also.  And a personal decision, containing no cosmic truth.
Edited by bobzeq25, 19 January 2021 - 02:25 PM.
  • stars n planets likes this
#3 stars n planets
stars n planets
Posted 19 January 2021 - 02:44 PM
I guess my question was wrong­čść . if i use a osc camera, would i get better Ha data from a tri/quad band filter or a dedicated Ha filter? The multiband would multiple layers so not?
Edited by stars n planets, 19 January 2021 - 02:46 PM.
#4 t-ara-fan
t-ara-fan
  • Loc: 50┬░ 13' N
Posted 20 January 2021 - 03:10 PM
See my comment (#7) here: https://www.cloudyni...s2-filter-data/
There is crosstalk between all the bands with a tri/quad band filter.   The Ha is effected the least because the other elements are fainter than Hydrogen. But S-II gets massive crosstalk from Ha so that isn't good.
#5 bobzeq25
bobzeq25
Posted 20 January 2021 - 06:32 PM
I guess my question was wrong . if i use a osc camera, would i get better Ha data from a tri/quad band filter or a dedicated Ha filter? The multiband would multiple layers so not?
I suppose it depends on exactly:
what the target is
what your setup is
what you're trying to do.
