Solar Orientation in Refractors
10 replies to this topic
#1 cptbobrfh
cptbobrfh
  • Loc: Walden N.Y.
Posted 20 January 2021 - 01:40 PM
Hello-
Does anyone use a 2" ERECT IMAGE DIAGONAL to visually see the Sun in the CORRECT up/down,left/right orientation?
Such as Baader 2" ERECT IMAGE DIAGONAL?
Thanks to all,
Bob
#2 sg6
sg6
  • Loc: Norfolk, UK.
Posted 20 January 2021 - 02:47 PM
Oddly it may be irrelevant.
The "top" and so "bottom" of the sun alters as you move North and South on the earth. Moon is the same.
Although the Sun remains "upright" the observer could be considered upright at the North Pole and "upside down" at the South Pole, and so the orientation of the sun appears to switch.
The old question of: Is the Moon upside down in Australia, No, but the observer is.
  • briansalomon1 likes this
#3 Couder
Couder
  • Loc: Mansfield, Missouri in the Ozarks
Posted 20 January 2021 - 03:19 PM
To tell which way I'm viewing the sun, I lightly tap the tube up and see which way it moves in the image, then I know which way is up.
  • BinoGuy and briansalomon1 like this
#4 dhkaiser
dhkaiser
Posted 20 January 2021 - 03:37 PM
To answer your question, no I do not use a correct image right angle (cira) diagonal.  Those would have to be used with a objective solar filter.  I use either a Herschel Wedge or a dedicated solar scope, neither of which is cira.  I'm sure your aware that the sun's tilt will vary throughout the year, so it is more than using a cira to determine solar north in the telescope.
To find the correct solar orientation in my telescopes I use the Tilting Sun software.  Using your location, time, date, mount type and diagonal use it gives the proper eyepiece view.
http://www.atoptics.co.uk/tiltsun.htm
  • BYoesle, Lost in Space, philmor56 and 1 other like this
#5 BYoesle
BYoesle
  • Loc: Washington USA
Posted 20 January 2021 - 03:55 PM
None that I know of. After all, there is no advantage other than orientation, and for astronomical objects, this is traditionally considered irrelevant.
A: Eyeball, B: Telescope, C: Telescope with diagonal mirror / prism.
On the other hand I sort of like the idea of eliminating the reversed mirror image shown in diagram C. If you have enough in-travel, a good alternative would be a pentaprism:
https://www.telescop...al/p/130301.uts
https://www.omegon.e...ab_bar_0_select
The standard Baader Amici prism diagonal is intended for terrestrial viewing at "low power." If you intend to use this for astronomical viewing, I'd recommend the more expensive version with BBHS coatings w Zeiss prisms.
These would be for use with front mounted solar filters.
A pentapism version of the Herschel wedge could also be employed as seen on right below:
And there's an interesting post on one being used here.
  • Jamey L Jenkins and dhkaiser like this
#6 chemman
chemman
  • Loc: Colorado
Posted 20 January 2021 - 08:45 PM
Great program Dan, Thanks.
  • dhkaiser likes this
#7 chemman
chemman
  • Loc: Colorado
Posted 20 January 2021 - 08:59 PM
Visually I am unconcerned about the Sun's orientation.  After all I am always looking at from a perpendicular angle when using a diagonal, If I wanted the orientation correct I  should be viewing it from a position of the Earth 3 months from now or 3 months ago, lol.  I typically assume when I am viewing straight through I am looking at it like it would look with solar binoculars, probably not so but it  is what runs through my head.  When I put a camera on the image plane sometimes I go to GONG and orient the camera to match it, I don't think that works either, lol.    It does seem to help me navigate when I am using the soda straw Barlow magnification though.
Nice discussion of this dilemma Bob.  Thanks
Chuck
Edited by chemman, 20 January 2021 - 09:00 PM.
#8 cptbobrfh
cptbobrfh
  • Loc: Walden N.Y.
Posted 20 January 2021 - 09:16 PM
As a strictly visual solar observer,I would like to see the Sun as is pictured on GONG,SOLARHAM.COM,DAYSTAR WEBSITE,as the Sun surface features come from behind,and rotate from the left(east) and move towards the right(west) as per the rotation of the Sun.
  • viewer likes this
#9 viewer
viewer
  • Loc: 60N, Helsinki, Finland
Posted 24 January 2021 - 07:49 AM
I have an erecting prism on my WL telescope, like it that way as OP. My HA PST telescope flips the image left/right and vertically, so after sketching I turn the sketch upside down for "correcting" directions. For getting the directions fine tuned I compare to SDO/GONG.
Edited by viewer, 24 January 2021 - 08:11 AM.
#10 rocketsteve
rocketsteve
  • Loc: DFW, Texas
Posted 24 January 2021 - 12:57 PM
You can also get correctly-oriented views of the sun online:
http://jsoc.stanford.../images/latest/
https://sohowww.nasc...me/hmi_igr/512/
#11 viewer
viewer
Posted 24 January 2021 - 01:39 PM
Yes, I think all of them have the sun's north pole up and south pole down. Not exactly how it looks when viewed from earth's northern hemisphere, but in the ballpark.
Edited by viewer, 24 January 2021 - 01:49 PM.
