Testing capture with short exposures / F10
18 replies to this topic
#1 SanjeevJoshi
SanjeevJoshi
  • Loc: Los Altos CA
Posted 21 January 2021 - 03:01 AM
Tonight was average seeing and getting worse as the evening progressed.   I tested out my earlier target -- M1 using the following set up for short exposures and high gains:
C8 Edge HD
ZWO 294 MC Pro, binned 2 x 2 (seeing did not permit usage at 1 x 1)
Exposures: 2 seconds and 5 seconds
Gains:  450 and 570 (max camera can do)
Sharpcap Pro
No darks or flats (i need to generate some darks at 2 x 2 binning)
Duration:  Roughly 10 mins
While the 294 is not a good fit for RASA 8, it seems to work well with my C8's.   Especially given the noise level is really low, I can turn up the gain very high.  So wanted to compare a couple of short exposures.
First here is
exposure = 2 seconds, gain = 570.  I kept the color saturation as low as possible to showcase the details a bit more.
  • Starman27, mehdymo and roelb like this
#2 SanjeevJoshi
SanjeevJoshi
  • Loc: Los Altos CA
Posted 21 January 2021 - 03:02 AM
exposure = 2 seconds, gain = 450.  Unfortunately I was a bit more aggressive on the color saturation, but you can still see the difference from gain = 570.
  • roelb likes this
#3 SanjeevJoshi
SanjeevJoshi
  • Loc: Los Altos CA
Posted 21 January 2021 - 03:03 AM
Exposure = 5 seconds, gain = 450.
  • roelb, dcweaver and hornjs like this
#4 SanjeevJoshi
SanjeevJoshi
  • Loc: Los Altos CA
Posted 21 January 2021 - 03:04 AM
And finally, exposure = 5 seconds, gain = 570 (max for camera).
Edited by SanjeevJoshi, 21 January 2021 - 03:05 AM.
  • roelb likes this
#5 SanjeevJoshi
SanjeevJoshi
  • Loc: Los Altos CA
Posted 21 January 2021 - 03:10 AM
I think 5S x gain 450 may be a tad better than 2S x 570 but its pretty close.   Which one do you think is the best?
Overall, I am impressed with what either can do.   Especially with 2S x 570, it opens up the potential to get a pretty close view in about 5 mins - although 8 to 10 mins seems to be ideal.
Using high gain with a camera like 294 may be a saving grace for slow systems in EAA.
Ignore the bands, they are a result of vignetting and weather.
#6 mehdymo
mehdymo
  • Loc: Florida
Posted 21 January 2021 - 04:24 AM
Very interesting. Thanks for sharing.
#7 GaryShaw
GaryShaw
  • Loc: Massachusetts / Wyoming
Posted 21 January 2021 - 09:05 AM
Hi
What makes you say the 294 is a bad match for the rasa?
Thank you for providing the experimentation above.
Gary
#8 SanjeevJoshi
SanjeevJoshi
  • Loc: Los Altos CA
Posted 21 January 2021 - 09:51 AM
Hi
Gary
294 under samples, specifically for RASA 8, and that’s on average seeing.  Worse with good seeing (prohibitive).   I would guess the same for any other C8 F2 system.
So while I love it for fitting and framing the largest DSO’s, a 183 (I own) or 533 (based on others) beats the pants off 294 wrt image quality / details.   Zooming, forget that.
I therefore use it for the really widefield (70 arc minutes plus) on RASA 8, and with native C8 F10.
With the 183, I can frame up to 70 arc minutes on RASA 8, and it works great for most seeing conditions.  I can also zoom into to see M1, and it’s a reasonable quality for a 5 arc minute object.  Just based on specs, 183 with the quality it provides is likely the best today for RASA 8 for versatility, 533 offers a different trade off with larger pixels and a square FoV.
There does not appear to be a camera that can work well with RASA 8 in excellent seeing (like a few times a year) to zoom in.  RASA 8 seems to need an even smaller pixel, big sensor with a deep enough well.   I don’t think most people are going to miss this much.
Edited by SanjeevJoshi, 21 January 2021 - 10:05 AM.
  • Rickster and dcweaver like this
#9 Borodog
Borodog
Posted 21 January 2021 - 10:10 AM
Were you guiding or just tracking?
Sadly I think I have too much plain old vibration to shoot even 2s with my F/10 C8. It’s fine for planetary or lunar because of the ultra short exposure times, but looks like hell for DSO.
#10 Borodog
Borodog
Posted 21 January 2021 - 10:14 AM
Also the RASA is so fast I think your best bet might be mosaics with a smaller sensor/pixel camera. I’m not sure well depth matters too much; just stack more frames.
Edited by Borodog, 21 January 2021 - 10:14 AM.
#11 SanjeevJoshi
SanjeevJoshi
  • Loc: Los Altos CA
Posted 21 January 2021 - 10:16 AM
Just tracking.   View was a bit jumpy just to seeing, scintillating stars.
Hmm I was using my AVX but even the Evo mount just do fine, I will need to use a star diagonal and be more careful since it’s a cooled camera, 133 mm back focus.
I am pretty sure it’s not a typical limitation for a Evo type mount.   Is yours old?
Edited by SanjeevJoshi, 21 January 2021 - 10:20 AM.
  • Borodog likes this
#12 SanjeevJoshi
SanjeevJoshi
  • Loc: Los Altos CA
Posted 21 January 2021 - 10:18 AM
Yes, I am too lazy to do mosaics.  I just enjoy it during the session, grab a couple pics if anything is worth saving.   I don’t have any processing programs.  Just good old Microsoft to crop and resize to fit the forum requirements.
#13 GaryShaw
GaryShaw
Posted 21 January 2021 - 05:45 PM
Luckily the RASA 11” that I’ve also been eye-ing does ok with the 294 from ‘very poor’ through ‘ok’ seeing. It even looks like it can push a bit into the ‘good’ range of seeing..... seldom experienced at my primary observing site anyway.
I’ve been wavering between the a RASA 8” versus 11” so perhaps this pushes me a bit towards the 11” although there are other factors that play into it besides my love of the 294. Thanks for making the comment Sanjeev.
Gary
#14 SanjeevJoshi
SanjeevJoshi
  • Loc: Los Altos CA
Posted 21 January 2021 - 05:57 PM
Gary
I love my RASA 8 no question.  But this is also true.  A RASA is such a worthy bucket list item, someday my dream would be to own a 11 or better yet a 14 on a fixed pier in my backyard.   Just switch a camera occasionally if needed, otherwise own the skies!   Without the specific experience of owning one, I would say 11 or 14 if I had a choice :)
in my case a long term move is inevitable, and I will need to start thinking of a more permanent system once I settle down.  Until then, it’s ridiculously easy to carry out the AVX and the RASA 8 does great with it.
Yes 294 should do much better with those.   I love the 294 and as you can see - even at max gain, the performance is great.
  • GaryShaw likes this
#15 donstim
donstim
  • Loc: Seattle Area, WA USA
Posted 21 January 2021 - 06:57 PM
Using such high gain values sacrifices a lot of dynamic range. On a mostly bright object and especially for EAA that should be an okay tradeoff for capture time as you have shown.
  • SanjeevJoshi likes this
#16 SanjeevJoshi
SanjeevJoshi
  • Loc: Los Altos CA
Posted 21 January 2021 - 07:37 PM
I agree.  Since I am looking at images captured in a few mins just for the sake of viewing and an observation log or a forum post, the quality is plenty good for me :)
Using 2 second exposures at high gain opens up the ability to use F10 at native resolution with shorter windows of time.
I am picking on M1 for a specific reason.  I continue to test M1 under varying conditions, OTA's, cameras, set ups.. its not an incredibly tough target but it is not a slam dunk like many others.   Seeing conditions, set ups will impact the views, so if I can get a EAA quality view thats comparable, mission accomplished!
  • donstim likes this
#17 Borodog
Borodog
Posted 21 January 2021 - 11:22 PM
Heh. My C8 is a 1985 Celestron-Byers Worm Gear Drive on an old Meade wedge on an even older C14 tripod.
You say that because you haven't tried Microsoft ICE (Image Composite Editor I think). Drag in images, click Next a couple times, nearly perfect mosaic every time. The image in this thread was nearly 30 individual tiles mosaiced in ICE with I think 2 clicks:
https://www.cloudyni...x#entry10772243
The original full size image is 33 Mpxl, FYI.
Edited by Borodog, 21 January 2021 - 11:24 PM.
  • dcweaver likes this
#18 DSO_Viewer
DSO_Viewer
Posted 22 January 2021 - 12:20 AM
How would you do mosaics anyways for EAA?
Steve
#19 DSO_Viewer
DSO_Viewer
Posted 22 January 2021 - 12:23 AM
Looking at your results definitely shows more sharpness and better contrast in the lower gain.
Steve
