Celestron NexImage 93709
beginner Celestron imaging
7 replies to this topic
#1 aescarbi
aescarbi
Posted 23 January 2021 - 09:56 AM
Hello everybody,
I have a Celestron NexImage 93709 camera, woriking with ICap 2.4. Even if my laptop detects the device, I cannot get a clear picture. It only shows a lighter or darker grey rectangle, depending on the amount of light which the camera captures. Not on the telescope nor as a normal camera I can get something remotely close to a picture. Am I doing something wrong? Should I suspect mulfunctioning of the camera?
I am most grateful for any advice.
#2 Dynan
Dynan
  • Loc: NOLA
Posted 23 January 2021 - 10:02 AM
Probably way out of focus.
  • PatrickVt and aescarbi like this
#3 michael8554
michael8554
  • Loc: Wiltshire UK
Posted 23 January 2021 - 10:28 AM
"Not on the telescope nor as a normal camera I can get something remotely close to a picture"
Which telescope ?
The camera must have a lens attached to show a recognisable image.
A telescope acts as a lens, but what lens were you using when "a normal camera" ?
So try it on a distant object on auto Exposure if iCap has that, during the day.
As Dynan says, probably out of focus, but without knowing your telescope I can't tell if good focus is possible or not.
Edited by michael8554, 23 January 2021 - 10:29 AM.
  • aescarbi likes this
#4 aescarbi
aescarbi
Posted 24 January 2021 - 08:26 AM
Thank you, michael8554. The telescope is a Celestron NexStar Evolution 8. With the Moon in focus, the camera only shows a light grey image, not very different of the picture I posted. The reference to it "as a normal camera" is because (I am new in this) I expected it to work as a normal webcam would, too. The camera has no physical focus control, and iCap auto exposure does not fix the problem. I cannot get a better picture even manually scrolling through the whole exposure range.
#5 Dynan
Dynan
  • Loc: NOLA
Posted 24 January 2021 - 09:01 AM
"With the Moon in focus..." The focus point of the camera may be a VERY different distance than that of an eyepiece.
And to be used as a webcam DOES require a lens be used in front of this camera. I have the same camera and found this to be true. (See lack of camera lens)
I suggest you rack your focuser all the way in with the camera taking short (≈ 0.05 seconds in daylight or ≈ 5.0 seconds at night) images. Then rack the focus out (out-focus) slowly until you have made full travel of the focus tube. If there is no focus in this range of motion, loosen the camera from its mounting and manually (and carefully keeping it in the line of sight of the scope) move the camera farther out from the focuser tube. You should at some point see something close to a clear image.
If this works, it indicates that your focuser's travel isn't long enough to reach focus and you'll need an extender(s).
If you need to go closer (in-focus movement isn't enough), there isn't much option to use that camera.
#6 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 24 January 2021 - 12:21 PM
As a further comment on the focus for a camera vs an eyepiece - Just remember for a target at infinity (like the moon) the sensor of the camera needs to be at the scope's focal plane, whereas with, say a 25mm eyepiece, you will have 25mm from the scope's focal plane to the lens in the eyepiece.
  • Dynan and aescarbi like this
#7 aescarbi
aescarbi
Posted 24 January 2021 - 08:53 PM
Dear all,
Thank you SO MUCH!
It was indeed a matter of focus (and ignorance, of course). I have a long way to learn to get good pictures, but today I was at least able to take my first ones!
Thanks again and all best to you!
  • Dynan likes this
#8 Dynan
Dynan
  • Loc: NOLA
Posted 24 January 2021 - 08:58 PM
Thanks for the Follow Up! We appreciate those. Now...a little bit better focus (and good seeing) and you'll be Top Notch!
Also tagged with one or more of these keywords: beginner, Celestron, imaging
