12V Power Supply
6 replies to this topic
#1 watty1959
watty1959
Posted 23 January 2021 - 10:20 AM
I have a Powerwerx 12V, 30A power supply.  The actual output voltage is 14.1V. Is this okay to use to power my 12V equipment such as cameras, focuser, etc?
#2 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 23 January 2021 - 10:24 AM
I've been using 13.8 volt pyramid power supplies for about 6 years now and never had a problem with any component. A regular lead/acid battery will put out 13.3 volts and many people power their systems with these.
Rgrds-Ross
  • bobzeq25 likes this
#3 LuscombeFlyer
LuscombeFlyer
  • Loc: Lakeland, FL
Posted 23 January 2021 - 10:37 AM
Yes, that shouldn't be a problem at all. Most "12 volt" power supplies are close to 13.8v, so that's a smidgen high, but not a problem.
#4 watty1959
watty1959
Posted 23 January 2021 - 10:42 AM
I thought it would be ok but I wanted to make sure. Thanks so much for your replies. I appreciate it.
Pat
#5 Maritime
Maritime
Posted 23 January 2021 - 11:07 AM
Wow, my favorite single engine.
#6 euthus
euthus
  • Loc: Naples, FL and Alexandria, MN
Posted 23 January 2021 - 12:24 PM
I also have a 30 amp Powerwerx power supply.  My voltage was a bit low.  I think it was KathyAstro, in one of her videos, who talked about being able to change the output voltage (within a small range) on these units.  I was able to increase mine a bit to get it closer to 13.8.
#7 kathyastro
kathyastro
  • Loc: Nova Scotia
Posted 23 January 2021 - 12:38 PM
I have been using that exact power supply for several years with no ill effects.  "12v" is a nominal standard only.  Most 12v power supplies deliver well over 12v so that they can charge a nominally-12v battery.
That wasn't me, but I remember that thread.  There is apparently an adjustment inside the device.
